关键词:模数转换器 SAR ADC 测试测量 医疗设备 ADI AD4698
时间:2022-05-11 16:53:23 来源:中电网
ADI公司的AD4698是 16位8路500kSPS/1MSPS容易驱动的多路复用逐次逼近式模拟数字转换器(SAR ADC), 多路复用输入精度SAR ADC,具有容易驱动特性和扩展数字功能.AD4697/AD4698具有不丢失码的真16位SAR ADC代码,8路低串扰多路复接器,一个灵活的通路顺序器,每个模拟输入过压保护箝位电路,片上过取样和抽取,阈值检测和警报指示器以及自动转换(autocycle)模式.器件先进数字功能使得AD4697/AD4698和低功耗数字主机变体兼容,低SPI时钟速率要求,片上定制化通路顺序器,过取样和抽取降低了数字主系统的负担. 自动转换(autocycle)模式和阈值检测特性赋能低功耗中断驱动固件设计,自动执行转换和基于通路指定的阈值极限所产生的警报. AD4697/AD4698可采用4.00 mm × 4.00 m24引脚LFCSP封装, AD4698可采用2.960 mm × 2.960 mm 36引脚WLCSP封装.工作温度−40°C到+125°C.主要用在光电二极管监测,医疗设备, 生命体征监测,测试测量,自动测试设备,仪器和过程控制以及电池供电设备.本文介绍了AD4698主要特性,功能框图,典型连接框图,评估板EVAL-AD4696FMCZ主要特性,简化框图和电路图与PCB设计图.
The AD4697/AD4698 are compact, high accuracy, low power, 8-channel, 16-bit, 500 kSPS/1 MSPS, multiplexed input precision, successive approximation register (SAR) analog-to-digital converters (ADCs) with Easy Drive features and extensive digital functionality.
The AD4697/AD4698 are optimal for use in space constrained, multichannel, precision data acquisition systems and monitoring circuits. The AD4697/AD4698 feature a true 16-bit SAR ADC core with no missing codes, an 8-channel, low crosstalk multiplexer, a
flexible channel sequencer, overvoltage protection clamp circuits on..
分享到:
