¹Ø¼ü´Ê£ºÊý¾ÝͨÐÅ ADI ADN4693E-1
ʱ¼ä£º2022-04-21 14:38:48 À´Ô´£ºÖеçÍø
ADI¹«Ë¾µÄADN4693E-1ÊÇÒ»¿î¶àµãµÍѹ²î·ÖÐźÅ(M-LVDS)ÊÕ·¢Æ÷(Çý¶¯Æ÷ºÍ½ÓÊÕÆ÷¶Ô), ¹¤×÷ËÙÂÊ×î¸ß¿É´ï200 Mbps (100 MHz)²»¹éÁã(NRZ). ½ÓÊÕÆ÷¿ÉÔÚ¸ÃÆ÷¼þµÄ¹²Ä£µçѹ·¶Î§ÄÚÀûÓõÍÖÁ¡À50 mVµÄ²î·ÖÊäÈë¼ì²â×ÜÏß״̬.´Ó×ÜÏßÒý½ÅÉÏʵÏָߴï¡À15 kVµÄ¾²µç·Åµç(ESD)±£»¤.ADN4693E-1×ñÑM-LVDSµÄTIA/EIA-899±ê×¼Éè¼Æ,ΪTIA/EIA-644 LVDSÆ÷¼þÌí¼ÓÁ˶îÍâµÄ¶àµãÄÜÁ¦. ȫ˫¹¤Æ÷¼þ²ÉÓýô´ÕµÄ16Òý½Å4 mm x 4mm LFCSP·â×°. ADN4693E-1²ÉÓþßÓÐ25 mV³ÙÖ͵Ä1Àà½ÓÊÕÆ÷£¬Òò´Ë»ºÂý±ä»¯µÄÐźŻòÊäÈëËðºÄ²»ÖÁÓÚÒýÆðÊä³öÕñµ´. ×ÜÏßÒý½ÅÌṩÔöÇ¿ÐÍESD±£»¤: ¿ÕÆø·Åµç£º¡Ý¡À15 kV HBM; ½Ó´¥·Åµç£º¡Ý¡À8 kV HBM; ¿ÕÆø·Åµç£º¡Ý¡À10 kV IEC 61000-4-2ºÍ½Ó´¥·Åµç£º¡Ý¡À8 kV IEC 61000-4-2.Æ÷¼þµÄ¶î¶¨Î¶ȷ¶Î§Îª-40⁰CÖÁ+120⁰C½áη¶Î§.Ö÷ÒªÓÃÔÚ±³°åºÍµçÀ¶àµãÊý¾Ý´«Êä,¶àµãʱÖÓ·ÖÅä,µÍ¹¦ºÄ¸ßËÙÌæ´úÆ÷¼þ,¿ÉËõ¶ÌRS-485Á´Â·ÒÔ¼°ÍøÂçºÍÎÞÏß»ùÕ¾»ù´¡ÉèÊ©,µçÍø»ù´¡ÉèÊ©ºÍ¼ÌµçÆ÷±£»¤ÏµÍ³.±¾ÎĽéÉÜÁËADN4693E-1Ö÷ÒªÌØÐÔ,¹¦ÄÜ¿òͼ, µäÐÍȫ˫¹¤M-LVDS¿ØÖÆÆ÷/Æ÷¼þÍøÂçÒÔ¼°ÆÀ¹À°åEVAL-ADN4693E-1EBZÖ÷ÒªÌØÐÔ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
The ADN4693E-1 is a multipoint, low voltage differential signaling (M-LVDS) transceiver (driver and receiver pair) that can operate at up to 200 Mbps (100 MHz) nonreturn to zero (NRZ). The receiver detects the bus state with a differential input of as little as ¡À50 mV
over the common-mode voltage range of the device. Electrostatic discharge (ESD) protection of up to ¡À15 kV is implemented on the bus pins. The ADN4693E-1 is designed to the TIA/EIA-899 standard for use in M-LVDS networks and complements TIA/EIA-644
LVDS devices with additional..
·ÖÏíµ½£º
²ÂÄãϲ»¶
