¹Ø¼ü´Ê£ºµçÔ´¹ÜÀí PFC Onsemi NCP1680
ʱ¼ä£º2022-04-19 11:11:14 À´Ô´£ºÖеçÍø
Onsemi¹«Ë¾µÄNCP1680ÊÇͼÌÚÖùÁٽ絼ͨģʽ(CrM) PFC¿ØÖÆÆ÷,ÓÃÀ´Çý¶¯ÎÞÇÅͼÌÚÖùPFCÍØÆË. ÎÞÇÅͼÌÚÖùPFCÊǹ¦ÂÊÒòËØÐÞÕý¼Ü¹¹,°üÀ¨PWM¿ª¹ØÆµÂʵĿìËÙ¿ª¹ØÍÈÇý¶¯ºÍ¹¤×÷ÔÚACÏß·ƵÂʵĵڶþÍÈ.ÕâÖÖÍØÆË²»ÐèҪͨ³£PFCµç·ÖÐËùÓõĶþ¼«¹ÜÇÅ,´Ó¶ø´ó´óµØ¸ÄÉÆÁ˹¦Âʼ¶Ð§ÂÊ.Ôڷdz£ÇáµÄ¸ºÔزÉÓÃÌøÔ¾Ä£Ê½ºÍÓÐËùȨµÄµçÁ÷¼ì²â·½°¸,Êý×Öµçѹ»ØÂ·²¹³¥,ACÏß·¼à²âµç·ºÍACÏàλ¼ì²â,ËùÓй¤×÷ģʽ¾ßÓнӽü1µÄ¹¦ÂÊϵÊý.Ö÷ÒªÓÃÔÚ¹¦ÂÊÒòËØÐÞÕý,¹¤ÒµµçÔ´ºÍÀëÏßµçÔ´.±¾ÎĽéÉÜÁËNCP1680Ö÷ÒªÌØÐÔºÍÖ÷ÒªÓÅÊÆ,Ó¦Óõç·ÒÔ¼°ÆÀ¹À°åNCP1680 EVBÖ÷°åºÍ×Ó°åÖ÷ÒªÖ¸±ê,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼Óë±äѹÆ÷Êý¾Ý±í.
NCP1680: Totem Pole Critical Conduction Mode (CrM) Power Factor Correction Controller
The NCP1680 is a CrM PFC controller IC designed to drive the bridgeless totem-pole PFC topology. The bridgeless totem-pole PFC is a power factor correction architecture that consists of a fast switching leg driven at the PWM switching frequency and a second leg that operates at the AC line frequency. This topology eliminates the diode bridge present at the input of a conventional PFC circuit, allowing significant improvement in the power stage efficiency.
NCP1680Ö÷ÒªÌØÐÔ:
Totem Pole PFC Topology Eliminates Input Diode Bridge
Critical Conduction Mode (CrM) Operation
Discontinuous Conduction Mode (DCM) with Valley Turn On Under Light Load Condition
Frequency Foldback in DCM With 25 kHz Minimum Frequency
Skip Mode in Very Light Load ..
·ÖÏíµ½£º
²ÂÄãϲ»¶
