关键词:马达控制 RS-422 RS-485 通信设备 Maxim MAX33076E
时间:2022-04-02 14:27:11 来源:中电网
Maxim公司的MAX33076E是高速四路RS-422/RS-485接收器,具有±65V故障保护,±25V CMR和±25kV ESD保护.工作电压+3.3V或+5.0V.真正的失效保护接收器防止接收器在输入短路或开路时假性瞬变.工作温度-40°C 到 +125°C,16引脚SOIC和QSOP封装,引脚和工业标准产品MAX3093-94 与MAX3095-96兼容,数据速率可选择20Mbps或 35Mbps.主要用在马达控制器,通信设备,电网设备,CNC机器和激光模块.本文介绍了MAX33076E主要优势和特性,框图, 典型应用电路和评估板MAX33076E Shield主要特性和优势,电路图,材料清单和PCB设计图.
The MAX33076-9E is a family of robust quad channel RS-485/422 receivers with high CMR (common mode range), high fault protection, and high ESD for harsh electrical environments. This family operates from a supply range of +3.3V or +5.0V.
These devices feature a high CMR of ±25V, which helps in reception of messages when the ground planes between two nodes have large differences or large external interference from motors or other electrical noise sources. These parts have extended fault protection of ±65V where the data lines are protected from accidental shorts to local power supplies. A high ESD HBM (human body model) of ±25kV also protects the data lines from ESD strikes either during production or in the field.
..分享到:
