Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]ADI ADRF5345¸ß¶ÈÏßÐÔ1.8-3.8GHz¹èSP4T¿ª¹Ø½â¾ö·½°¸
¹Ø¼ü´Ê£ºÍ¨ÐŹ¤Òµ ΢²¨Í¨ÐÅ ÏßÐÔ¿ª¹Ø SP4T ADI ADRF5345
ʱ¼ä£º2022-01-12 16:28:58       À´Ô´£ºÖеçÍø
ADI¹«Ë¾µÄADRF5345ÊǸ߶ÈÏßÐÔµ¥µ¶ËÄÖÀ(SP4T)¿ª¹Ø,²ÉÓù蹤ÒÕ¼¼ÊõÖÆÔì,¹¤×÷ƵÂÊ´Ó1.8GHzµ½3.8GHz,µäÐ͵IJåÈëËðºÄСÓÚ0.4dB,ÊäÈëIP3µäÐÍΪ84dBm.Æ÷¼þ¾ßÓÐRFÊäÈ빦ÂÊ´¦ÀíÄÜÁ¦39dBmÁ¬Ðø²¨ÐźÅ,¶ø¶ÔLTEÐÅºÅÆ½¾ù¹¦ÂÊΪ39dBm,·åÖµ¹¦ÂÊΪ49dBm.ADRF5345¼¯³ÉÁ˸ºµçѹ·¢ÉúÆ÷(NVG)ºÍµ¥¸öÕýµçÔ´5V(VDD)¹¤×÷,×÷ÓÃÓÚVDDÒý½Å,ÏûºÄ2mAµçÁ÷.Æ÷¼þ²ÉÓõÍѹ»¥²¹½ðÊô-Ñõ»¯Îï°ëµ¼Ìå(LVCMOS)/µÍѹ¾§Ìå¹Ü-¾§Ìå¹ÜÂß¼­(LVTTL)¼æÈÝ¿ØÖÆ.Æ÷¼þ²ÉÓÃ4mmx4mm 22¶ËRoHS¼æÈÝLGA·â×°,¹¤×÷ζÈ−40¡ãCµ½ +105¡ãC.Ö÷ÒªÓÃÔÚ5GÇãбÌìÏß,ÎÞÏß»ù´¡É豸,¾üÓú͸߿ɿ¿ÐÔÓ¦ÓÃ,²âÊÔ²âÁ¿ÒÔ¼°PIN¶þ¼«¹ÜÌæ´ú.±¾ÎĽéÉÜÁËADRF5345Ö÷ÒªÌØÐÔºÍÖ÷ÒªÖ¸±ê,¹¦ÄÜ¿òͼ,ÍÆ¼öÓ¦Óõç·,ÒÔ¼°ÆÀ¹À°åADRF5345-EVALZÖ÷ÒªÌØÐÔ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCB×°Åäͼ.
The ADRF5345 is a high linearity, reflective, single-pole, four-throw(SP4T) switch manufactured in the silicon process.
The ADRF5345 operates from 1.8 GHz to 3.8 GHz with a typicalinsertion loss lower than 0.40 dB and a typical input IP3 of 84 dBm.
The device has an RF input power handling capability of 39 dBm forcontinuous wave signals and 39 dBm average and 49 dBm peak forlong-term evolution (LTE) signals
The ADRF5345 incorporates an integrated negative voltage generator(NVG) to operate with a single positive supply of 5 V (VDD)applied to the VDD pin drawing a 2 mA supply current. The deviceemploys low voltage complementary metal-oxide semiconductor
(LVCMOS)-/low voltage transistor to transistor logic (LVTTL)- co..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
