Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]Maxim MAX77840´øUSB BC1.2¼ì²âºÍµçÁ¿¼Æ3A½µÑ¹³äµçÆ÷½â¾ö·½°¸
¹Ø¼ü´Ê£ºµçÔ´¹ÜÀí ³äµçÆ÷ ModelGauge m5µç¼ÆÁ¿ Maxim MAX77840
ʱ¼ä£º2021-09-16 13:46:44       À´Ô´£ºÖеçÍø
Maxim¹«Ë¾µÄMAX77840ÊÇ3.15A¿ª¹ØÄ£Ê½³äµçÆ÷ºÍModelGauge m5µçÁ¿¼Æ,¼¯³ÉÁËÓÃÓÚï®µç³ØµÄUSB BC1.2¼ì²âºÍÒ»¸öSAFEOUT LDO .³äµçÆ÷¼¯³ÉÁËËùÓеĿª¹ØºÍ¹¤×÷ÔÚ4MHz»ò2MHz(¿É±à³Ì)¿ª¹ØÆµÂÊ,ÔÊÐíÑ¡Ôñ×îСµÄÍâ½ÓÔª¼þ»ò»ñµÃ×îµÍµÄÈÈËðºÄ.MAX77840·Ç³£ÊʺÏÓÃÔÚÒÆ¶¯POSÉ豸,ÊÖ³ÖÒ½ÁƵç×ÓÉ豸»òÆäËüÊÖ³ÖÉ豸.Ëü°üÀ¨USB BC1.2¼ì²â¹¦ÄÜ,ÒÔʶ±ð¹²Í¨USBÊÊÅäÆ÷,²¢×Ô¶¯É趨ÊäÈëµçÁ÷ÏÞÖÆ. MAX77840 ÄÜÌṩ¸ß´ï1.5A OTGµçÁ÷ºÍÓÐËùÓÐȨMAXOTG±£»¤,ËüÏÞÖÆOTGÊä³öµçÁ÷,ÒÔ·ÀֹϵͳµçѹÔÚÖØOTG¸ºÔØÏµıÀÀ£.ModelGauge m5µçÁ¿¼ÆÌṩµç³ØµçÁ¿¾«È·¼ÆÁ¿,´ý»ú»ò˯Ãßģʽʱ¹¤×÷ÔÚ¼«µÍµÄµç³ØµçÁ÷(µäÐÍΪ25¦ÌA),ÒÔÀ©Õ¹µç³ØÊÙÃü.ModelGauge m5ºÍ³äµçÆ÷¼äµÄ½»»¥ÎªÖÕ¶ËÓû§ÌṩÁ˵¥¸öICµÄÓÅÒìµÄ³äµçÌåÑé.Æ÷¼þ¾ßÓиߴï16V±£»¤,¸ß´ï13.4VÊäÈ빤×÷·¶Î§,¸ß´ï4.0AÊäÈëµçÁ÷ÏÞÁ¿,¸ß´ï3.15Aµç³Ø³äµçµçÁ÷ÏÞÖÆ,²ÉÓÃCC,CVºÍоƬζȿØÖÆ,СÐ͵ç¸Ð0.47¦ÌH»ò1¦ÌH·â×°,I2C 3.0 ¼æÈݽӿںÍÖжÏÊä³ö,3.87mm x 3.96mm 9 x 9ÕóÁÐWLP·â×°.Ö÷ÒªÓÃÔÚ¹¤ÒµPC,ÊÖ³ÖÒ½ÁÆÉ豸,ÒÆ¶¯POSÉ豸,ÎÞÏßÑïÉùÆ÷,ÖÇÄܼÒÍ¥×Ô¶¯»¯ºÍ´«¸ÐÆ÷,ÎïÁªÍø(IoT).±¾ÎĽéÉÜÁËMAX77840Ö÷ÒªÓÅÊÆºÍÌØÐÔ,¼ò»¯¿òͼºÍ¿ª¹Ø³äµçÆ÷¿òͼ, µäÐÍÓ¦Óõç·ͼÒÔ¼°ÆÀ¹À°åMAX77840 EVKÖ÷ÒªÓÅÊÆºÍÌØÐÔ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
 The MAX77840 is a 3.15A switched-mode charger and ModelGauge™ m5 fuel gauge with integrated USB BC1.2 detection for Li-ion batteries and a SAFEOUT LDO.
The charger integrates all switches and operates at either 4MHz or 2MHz (programmable) switching frequency, allowing selection of the smallest external components or achieving lowest heat dissipation. The MAX77840 is ideally suited for devices such as mobile point-of-sale devices, portable medical electronics, or other handheld devices. I..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
