¹Ø¼ü´Ê£ºÎÞÏßͨÐÅ TDDʱ·Ö¸´Óà ADI ADRF5515A
ʱ¼ä£º2021-09-01 16:42:37 À´Ô´£ºÖеçÍø
ADI¹«Ë¾µÄADRF5515AÊÇ˫·¼¯³ÉÁËRF,ǰ¶Ë¶àоƬģ¿é,Éè¼ÆÓÃÓÚʱ·Ö¸´ÓÃ(TDD)Ó¦ÓÃ.Æ÷¼þ¹¤×÷ƵÂÊ´Ó3.3GHzµ½4.0GHz.Æ÷¼þ¿ÉÅäÖóÉ˫·ºÍ¼¶ÁªÁ½¼¶µÍÔëÒô·Å´óÆ÷(LNA)ºÍ´ó¹¦Âʹ赥µ¶Ë«ÖÀ(SPDT)¿ª¹Ø.ÔÚ¸ßÔöÒæÄ£Ê½,¼¶ÁªµÄÁ½¼¶LNAºÍ¿ª¹ØÌṩµÍÔëÒô1.05dBºÍ3.6GHzʱµÄ¸ßÔöÒæ36dB,¶øÊä³öÈý½×½»µ÷½ØÈ¡µã(OIP3)Ϊ35dBm(µäÐÍÖµ).ÔÚµÍÔöÒæÄ£Ê½,Á½¼¶LNAµÄÒ»¼¶´¦ÓÚÅÔͨ,Ôڵ͵çÁ÷48mAʱÌṩ17dBÔöÒæ.ÔÚ½µ¹¦ºÄģʽ,LNA¹Ø¶Ï,Æ÷¼þ½öÏûºÄ13mAµçÁ÷.ÔÚ·¢Ë͹¤×÷,µ±RFÊäÈëÁ¬½Ó¶ËÒý½Å(TERM-CHA»òTERM-CHB),¿ª¹ØÌṩµÍ²åÈëËðºÄ0.5dB,ÔÚÕû¸öÉúÃüÖÜÆÚ¹¤×÷Öд¦Àí³¤ÆÚÑݽø¼¼Êõ(LTE)ƽ¾ù¹¦ÂÊ43dBm(9dB·åÖµµ½Æ½¾ù±È(PAR)).Æ÷¼þÊÇRoHS¼æÈÝ,²ÉÓýô´Õ6mmx6mm 40Òý½ÅLFCSP·â×°.Ö÷ÒªÓÃÔÚÎÞÏßͨÐÅ»ù´¡É豸,TDD´ó¹æÄ£¶àÊäÈë¶àÊä³öÓÐÔ´ÌìÏßϵͳÒÔ¼°»ùÓÚTDDµÄͨÐÅϵͳ.±¾ÎĽéÉÜÁËADRF5515AÖ÷ÒªÌØÐÔ,¹¦ÄÜ¿òͼ,Ö÷ÒªµçÌØÐÔÐÔÄܱíÒÔ¼°20WÆÀ¹À°åADRF5515A-EVALZÖ÷ÒªÌØÐÔ,²âÊÔ½¨Á¢Í¼,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCB×°Åäͼ.
The ADRF5515A is a dual-channel, integrated RF, front-end, multichipmodule designed for time division duplexing (TDD) applications.
The device operates from 3.3 GHz to 4.0 GHz. TheADRF5515A is configured in dual channels with a cascading,two-stage low noise amplifier (LNA) and a high-power silicon singlepole,double-throw (SPDT) switch.
In high gain mode, the cascaded two-stage LNA and switch offer alow noise figure of 1.05 dB and a high gain of 36 dB at 3.6 GHz,with an output third-order intercept (OIP3) point of 35 dBm (typical).
In low gain mode, one stage of the two-stage LNA is in bypass,providing 17 dB of gain at a lower current..
·ÖÏíµ½£º
²ÂÄãϲ»¶
