[原创]Microchip HELLO FPGA板中低级开发方案
关键词:Arm Cortex-M3 MCU SmartFusion2 FPGA Microchip
时间:2021-08-04 16:18:52       来源:中电网
Microchip公司的HELLO FPGA板是低成本和紧凑尺寸的开发板,基于有Arm® Cortex®-M3处理器的SmartFusion®2 FPGA和嵌入闪存,支持电源演示,提供各种平台以方便设计你的原型产品.具有Arduino和mikroBUS™连接器, Hello FPGA板支持各种扩展板以用于更多的原型产品. Hello FPGA板可以验证SmartFusion2 SoC FPGA的特性:DSP功能:FPGA处理有GUI参数所定义的输入波形和显示瞬时接通输出波形. HELLO FPGA Kit包括有SmartFusion2 M2S010-1VF256的FPGA主板,照相机传感器板(LI-0V7725-MICRO v1.0),LCD板, USB 2.0 A到Mini-B电缆和快速起动卡.HELLO FPGA Kit主要特性包括基于M2S010-1VF256 SmartFusion2 FPGA,包含3x按扭,5x LED,FPGA JTAG接口, PICkit接口, PIC® MCU(PIC32MX79SF512L),开发板具有8MB SPI闪存和8Gb DDR3,和照相机传感器板的接口,以及其显示板的接口.本文介绍了HELLO FPGA Kit主要特性,外形图和主要部件图,以及HELLO FPGA Kit板电路图.
Low-cost and compact-sized, the Hello FPGA kit is for anyone with low to medium FPGA knowledge. Based on the SmartFusion®2 FPGA with its Arm® Cortex®-M3 processor with embedded Flash, the kit supports power demos and provides a versatile platform for you to prototype your designs. With Arduino and mikroBUS™ connectors, Hello FPGA supports additional expansion boards for more prototyping capabilities.
This kit can work as a standalone unit, as well as an extension to existing Microchip kits over the PICkit™ Header.
The Hello FPGA Kit d..
查看全文
