[原创]Infineon 1ED44175N01B IGBT栅极驱动器解决方案
关键词:电源管理 IGBT栅极驱动器 Infineon 1ED44175N01B
时间:2021-07-02 13:33:03       来源:中电网
Infineon公司的1ED44175N01B是具有过流保护的单路低边IGBT栅极驱动器.逻辑输入和标准CMOS和LSTTL输出.输出驱动器是电流缓冲器级.1ED44175N01B有用于过流保护检测的OCP引脚和FAULT状态输出.VCC引脚的内部电路提供欠压锁住保护,维持输出低电平,直至Vcc电源电压升至在工作范围内.过流阈值-0.246V,精度±5%容差.单引脚用于故障输出和使能,可编程故障清理时间,欠压锁住IGBT,CMOS施密特触发输入,3.3V,5V和15V输出逻辑兼容,最大25V VCC电压电源,3 kV ESD HBM和RoHS兼容,主要用在家用电器,空调,工业电器和用于单-单-端拓扑的通用低边栅极驱动器.本文介绍了1ED44175N01B主要特性,框图,升压应用电路以及5 kW两路交错CCM PFC评估板EVAL-PFC5KIKWWR5SY主要特性和主要指标,电路图,材料清单和PCB设计图.
The 1ED44175N01B is a low-voltage, power IGBT, non-inverting gate driver. Proprietary latch-up immune CMOS technologies enable ruggedized monolithic construction. The logic input is compatible with standard CMOS or LSTTL output. The output driver features a current buffer stage. The 1ED44175N01B has OCP pin for over current protection sense and a FAULT status output (when activivated, EN/FLT pin is internally pulled down). The EN/FLT needs to be externally pulled up to provide normal operation, pulling EN/FLT low disable the driver. Internal circuitry on VCC pin provides an under voltage lockout protection that holds output low until Vcc supply voltage is within operating range.
1ED44175N01B主要特性:
查看全文
