[原创]Maxim MAX25520汽车两路TFT-LCD电源方案
关键词:电源管理 汽车电子 TFT-LCD Maxim MAX25520
时间:2021-03-24 16:04:48       来源:中电网
Maxim公司的MAX25520是双路输出功率集成电路,提供对称或非对称正和负电压,高达10.5V和低至-10.5V,而输入电压在2.65V和5.5V之间.器件采用全集成了外接整流器的电流模式升压转换器和电流模式逆变器.器件工作两个频率420kHz或2.1MHz.工作在2.1MHz的器件允许非常紧凑的双输出电源.双输出电压可单独编程或能互相跟踪.单独使能引脚有完全的灵活性,是输出增加和降低.输出电压具有过流和欠压保护.器件采用3x3mm TQFN封装,工作温度-40 到125C .主要用在娱乐显示器,中央信息显示器和仪表盘.本文介绍了MAX25520主要优势和特性,功能框图,几种应用电路以及评估板MAX25520 EVK主要特性,电路图,材料清单和PCB设计图.
 The MAX25520 is a dual-output power IC that provides symmetrical or asymmetrical positive and negative volt­ages up to 10.5V and down to -10.5V with an input voltage between 2.65V and 5.5V. It incorporates a fully integrated current-mode boost converter and a current-mode inverter with external rectifier. The device operates at one of two switching frequencies, 420kHz or 2.1MHz. Operation at 2.1MHz permits very compact dual-output power supplies.
The two output voltages can be programmed indepen­dently or can be made to track each other. Independent enable pins allow complete flexibility in powering the out­puts up and down.
The outputs are protected against overcurrent and under­voltage.
查看全文
