[原创]ST RHRPMPOL01耐辐射和SEE硬化7A同步降压稳压器解决方案
关键词:电源管理 耐辐射 稳压器 ST RHRPMPOL01
时间:2020-12-09 12:15:56       来源:中电网
ST公司的RHRPMPOL01是单相降压单片开关稳压器,集成了高精度内部基准电压和用于同步转换的功率MOSFET.器件采用SOI技术,对单粒子闩锁效应有良好的性能.RHRPMPOL01能输入电压3.0V到12V转换成 8V到0.85xVIN输出电压.设计用在空间应用的FPGA,DSP,MCU和ASIC的电源.器件的控制器是基于峰值电流架构,从而保证了快的负载瞬态响应和很稳定的开关频率.嵌入的积分器补偿由于输出电压波纹所引起的DC电压误差.故障管理包括非闭锁输出过压保护,过流保护和自动恢复的热保护.输出电流高达7A,工作温度-55 C 到 +125 C,可编开关频率从100kHz到1MHz.RHRPMPOL01总离子剂量为100 krad,无单粒子闩锁效应高达70 MeV/mg/cm2 (@ VCC up to 7 V),SEU-SEFI特性高达VCC 7V,无质子.主要用在空间应用的点负载稳压器,FPGA,DSP,CPU和ASIC电源以及低压高密度分布电源系统.本文介绍了RHRPMPOL01主要特性,框图,典型应用电路图及其
外用元件表.以及评估板EVAL-RHRPMPOL01主要特性,电路图,材料清单和PCB设计图.
The RHRPMPOL01 is a single phase, step-down monolithic switching regulator with
high precision internal voltage reference and integrated power MOSFETs forsynchronous conversion. The device has been developed using SOI technology thatoffers good performance against SEL effect.
The regulator converts 3.0 V to 12 V input voltage to 0.8 V to (0.85xVIN) outputvoltage. It has been designed to supply FPGA, DSP, MCU and ASICS in general forspace applications.
The controller is based on peak current mode architecture, which ensures a fast load
查看全文
