[原创]TI DP83TD510EIEEE 802.3CG 10BASE-T1L以太网PHY解决方案
关键词:以太网 IEEE802.3cg 10Base-T1L PHY 过程控制 工厂自动化 HVAC控制器
时间:2020-11-05 15:33:44       来源:中电网
TI公司的DP83TD510E是超低功耗以太网物理层收发器,和IEEE 802.3CG 10BASE-T1L指标兼容.PHY有非常低噪音接收器架构,使得能使用长电缆和具有非常低功耗.DP83TD510E有外接MDI端口,支持本征安全要求.通过MII,简化板MII (RMII) , RGMI以及RMII低功耗5MHz主模式和MAC层接口.它还支持RMII背对背模式,以应用在需要超过1700米长度的应用.DP83TD510E提供集成的电缆诊断工具,内置自测和环回功能,以方便设计或调试.时钟输出25 MHz和50 MHz (RMII主),MDI引脚±6-kV HBM ESD保护,工作电压3.3V,工作温度–40C到105C,5 mm x 5 mm 32引脚封装.主要用在过程控制,现场发送器和交换,建筑物自动化如HVAC控制器,电梯和升降机,消防安全,以及工厂自动化和控制.本文介绍了DP83TD510E主要特性,功能框图和应用框图,以及评估模块DP83TD510E-EVM主要特性,框图,电路图,材料清单和PCB设计图.
The DP83TD510E is an ultra-low power Ethernetphysical layer transceiver compliant with the IEEE802.3cg 10Base-T1L specification. The PHY has verylow noise coupled receiver architecture enabling longcable reach and very low power dissipation. TheDP83TD510E has external MDI termination to supportintrinsic safety requirements. It interfaces with MAClayer through MII, Reduced MII (RMII) , RGMII, andRMII low power 5-MHz master mode. It also supportsRMII back-to-back mode for applications that requirecable reach extension beyond 1700 meters. Itsupports a 25MHz reference clock output to clockother modules on the system. The DP83TD510Eoffers integrated cable diagnostic tools; built-in selftest,and loopback cap..
查看全文
