[原创]Renesas RA4W1高效48MHz ARM MCU开发方案
关键词:Arm Cortex-M4 MCU 低功耗蓝牙 BLE Renesas RA4W1
时间:2020-10-28 12:13:44       来源:中电网
Renesas公司的RA4W1是高效48MHz基于Arm® Cortex®-M4核的MCU,具有512KB代码闪存,96KB SRAM,段式LCD控制器,容性触摸检测单元,蓝牙低功耗,USB 2.0全速,14位ADC,12位DAC以及其安全特性.微控制器(MCU)集成了多种系列软件和引脚兼容的基于Arm® 32位核,共享Renesas公司外设共同集,以方便设计升级和基于平台的有效产品开发.适用于需要安全性大容量RAM和低功耗的物联网应用以及安全装置(火灾探测,防盗检测,面板控制),表计类产品(电力,自动抄表),工业应用(机器人,开门器,缝纫机,自动售货机,UPS),健康管理和可穿戴人体传感器与智能家居和遥控玩具.本文介绍了RA4W1主要特性,框图和评估板EK-RA4W1主要特性指标,框图和元件布局图,电路图,材料清单和PCB设计图.
High efficiency 48-MHz Arm® Cortex®-M4 core, 512-KB code flash memory, 96-KB SRAM, Segment LCD Controller,Capacitive Touch Sensing Unit, Bluetooth Low Energy, USB 2.0 Full-Speed, 14-Bit A/D Converter, 12-Bit D/A Converter,security and safety features.
The MCU integrates multiple series of software- and pin-compatible Arm®-based 32-bit cores that share a common setof Renesas peripherals to facilitate design scalability and efficient platform-based product development.
The MCU in this series incorporates a low-power and high-performance Arm Cortex®-M4 32-bit core running up to48 MHz, with the following features:
· 512-KB code flash memory
· 96-KB SRAM
· Bluetooth Low Energy (BLE)
· Segment LCD Controller (SLCDC)
查看全文
