关键词:电源管理 AC/DC转换器 PWM TI TIDM-1001
时间:2020-09-22 14:38:39 来源:中电网
TI公司的TIDM-1001是采用TMS320F280025C MCU的数控500W两相交错LLC谐振转换器参考设计. TMS320F280025C能在所有工作条件下产生脉宽调制(PWM)波形,用于所有的功率开关器件.该设计采用创新的电流共享技术,以便在两相中精确地平衡电流.而谐振转换器是用在服务器,通信,汽车,工业和其它电源应用的受欢迎的DC/DC转换器,是中高功率应用的很好的选择,因为提高了工业标准,增加功率密度和高性能(效率,功率密度等等)标准.参考设计TIDM-1001满负载功率为500W(每相250W)或满负载时42.5A,输入电压Vin为370V到410VDC,输出电压Vout为12VDC.谐振频率为250kHz,开关频率200kHz到350kHz,峰值效率94.5%,无需加任何硬件两相间就有极好电流共享.故障保持稳定包括相和输出过流和输出过压,支持各种的C2000 powerSUITE工具.主要用在服务器电源,通信整流器,汽车充电和工业电源.本文介绍了参考设计TIDM-1001主要特性和性能指标,框图, HB LLC转换器和两相交错HB LLC转换器框图,多种HB PWM驱动电路图以及参考设计TIDM-1001电路图,材料清单和PCB设计图.
This reference design implements a digitally controlled, 500-W, two-phase interleaved LLC resonant converter. The system is controlled by a single, C2000 microcontroller (MCU),
TMS320F280025C, which also generates pulse width modulation (PWM) waveforms for all power electronic switching devices under all operating modes. This design implements an innovative current sharing technique to accurately achieve current balancing between phases.
Resonant converters are popular DC-DC converters frequently used in server, telecom, automotive, industrial, and other power supply applications. The converters are a good choice for me..
分享到:
