关键词:电源管理 DC/DC转换器 Maxim MAX20796
时间:2020-09-09 15:00:11 来源:中电网
Maxim公司的MAX20796是全集成高效率两相开关稳压器,工作电压从4.5V到16V,负载电流高达60A,外接功率级三相可达90A.通过占空比的某些限制输出电压可配置在0.5V至5.5V.开关稳压器采用固定频率控制方案,具有极紧凑快速和精确的服务器和通信应用的供电解决方案.集成的线性稳压器允许使用单电源工作.为了进一步提高系统效率和热性能,外接3.3V电源或FET用来产生核电源.主要的系统参数可以通过外接电阻进行配置,包括选择软起动时序,输出电压,开关频率, PMBus地址,过电流跳闸点和回路控制参数.器件可工作在耦合电感或分立电感,而耦合电感技术提供高性能与最低数量的输入和输出电容.在VIN = 12V, VOUT = 1V时峰值效率为92%,满负载效率为90%.器件工作结温-40C至125C,封装为35引脚4 ×10.5mm, 0.5mm点距的FC2QFN封装.主要用在点负载电压稳压器,通信,网络,服务器和存储设备,微处理器芯片组和存储器VDDQ以及I/O和辅助电源.本文介绍了MAX20796主要优势和特性,框图,多种应用电路,以及评估板MAX20796 EVK主要特性,电路图,材料清单和PCB设计图.
The MAX20796 offers a fully integrated, highly efficient, two-phase switching regulator for applications operating from 4.5V to 16V and requiring up to 60A maximum load or 90A with an optional third-phase external power stage. The output voltage range can be configured from 0.5V to 5.5V with some restrictions on duty cycle. The switching regulator uses a fixed-frequency control scheme providing an extremely compact, fast, and accurate power delivery solution for server and telecom applications. Integrated linear regulators allow single-supply operation. To further improve system efficiency and thermal performance, an exte..
分享到:
