ADI公司的LTC2971, LTC2971-1, LTC2971-2和LTC2971-3是两路高压电源系统管理器,用来加电次序, 微调(伺服),电源差额,监测,管理故障,提供遥测和记录故障. C采用专用的软连接算法以最大限度降低电源干扰.监测功能包括对两个电源输出通路和一个输入通路进行过压和欠压以及温度阈值限制.可编故障响应能禁止电源, 配置重试,触发黑匣子EEPROM存储故障状态以及相关的遥测.内部的16位ADC监测两种输出电压,两种输出通路,两个外部温度,输入电压和电流和芯片温度.输入功率,能量和输出功率也在计算.可编看门狗监视微处理器活性和必要时的重置.单线总线同步多个ADI电源管理系统(PSM)器件的电源.可配置的带ECC的EEPROM支持自主操作而不需要增加软件.1.8V到3.3V 的PMBus/SMBus/I2C 兼容串行接口.工作电压3.3V,或 4.5V 到 60V,49引脚7x7mm BGA封装.主要用在计算机和网络服务器,工业测试和测量,高可靠性系统,视频和医学图像.本文介绍了LTC2971主要特性,框图和多种应用电路,以及演示板DC2875A主要特性和指标,电路图和PCB设计图.
The LTCR2971, LTC2971-1, LTC2971-2, and LTC2971-3 are 2-channel high voltage Power System Managers used to sequence, trim (servo), margin, supervise, manage faults, provide telemetry and log faults. DACs use a proprietary soft-connect algorithm to minimize supply disturbances.
Supervisory functions include over and under voltage and temperature threshold limits for two power supply output channels and one input channel. Programmable fault responses can disable the power supplies, configure retry, and trigger black box EEPROM storage of fault status and associated telemetry. An internal 16-bit ADC monitors..
分享到:
