ST公司的STCMB1是集成了转换(TM)模式PFC和半桥谐振LLC高压双端控制器, 耐压800V的高压线路以及控制管理线路.PFC部分采用专有的恒定实时控制方法,不需要正弦输入基准,因此降低了系统成本和外接元件数量.它包括完整的保护特性如逐个周期的过流保护(OCP),输出过压保护(OVP)和反馈失败(FFP,锁存模式),AC电压降低,在起动时和电源下降或缺失周期后的升压电感饱和过充电流检测.半桥(HB)部分提供两个互补输出,180°反相驱动高边和低边MOSFET,在一个开关关断而另一个开关接通时间插入死区,这是自动调整的,以保证开关切换时零电压,从而获得低到满负载时的更高效率.而专有的控制方法, 时移控制(TSC),改善了动态性能和输入波纹抑制,使得输出波形更加清澈.主要用在AC/DC适配器,开框开关电源(SMPS), LED TV,台式电脑和全合一PC的开关电源,和节能兼容的消费类电子和工业SMPS,以及其LED街区照明. 中电网为您整理如下详细资料,本文介绍了STCMB1主要特性,框图和系统框图,典型应用电路和评估板EVL150W-HVSL(150V-150W LED驱动器)主要特性,电路图和材料清单以及扩展火线输入电压(85 ÷ 300 Vac)电路图和欧洲输入火线电压(195 ÷ 265 Vac)电路图.
The STCMB1 device embodies a transition mode (TM) PFC, a high voltage double-ended controller for LLC resonant half-bridge, an 800 V-rated high voltage section and the glue logic that supervises the operation of these three blocks.
The PFC section uses a proprietary constant on-time control methodology that does not require a sinusoidal input reference, thereby reducing the system cost and external component count.
It includes also a complete set of protections: a cycle-by-cycle overcurrent (OCP), an outputovervoltage (OVP), a feedback failure (FFP, latch-mode), an ac brown-out, boost inductorsaturatio..
分享到:
