[原创] TI TPS546D24A两相80A同步降压转换器参考设计
关键词:电源管理 DC/DC转换器 TPS546D24A
时间:2020-04-24 11:09:08       来源:中电网
TI公司的TPS546D24A是高度集成非隔离PMBus®Buck DC/DC转换器,具有高频工作,输出电流40A,封装为7mmx5mm 40引脚QFN封装.PVIN为2.95V到16V,输出电流高达40A,多达4个可堆栈.TPS546D24A采用专有的固定频率电流模式控制,具有输入正馈和可选择的内部补偿元件,以最小化尺寸和大范围输出电容下稳定性.PMBus接口具有1MHz时钟,支持方便标准化的数字接口,用于转换器配置和监视主要参数包括输出电压,输出电流和内部芯片温度.器件集成了4.5-mΩ/0.9-mΩ MOSFET.12个可选开关频率,从225 kHz 到1.5 MHz.主要用在数据中心交换,机架式服务器,有源天线系统,遥控无线电和基带单元,自动测试,CT,PET和MRI以及ASIC,SoC,FPGA,DSP核和I/O电压.中电网为您整理如下详细资料,本文介绍了TPS546D24A主要特性,功能框图,平均电流模式控制框图,两种单独应用电路和设计参数,以及两相评估模块TPS546D24AEVM-2PH主要特性和指标,电路图,材料清单和PCB设计图.
The TPS546D24A is a highly integrated, non-isolated DC/DC converter capable of high frequency operation and 40-A current output from a 7-mm × 5-mm package. Two, three, and four TPS546D24A devices can be interconnected to provide up to 160 A on a single output. The device has an option to overdrive the internal 5-V LDO with an external 5-V supply via the VDD5 pin to improve efficiency and reduce power dissipation of the converter.
The TPS546D24A uses a proprietary fixed-frequency current-mode control with input feedforward and selectable internal compensation components for minimal size and stability over a wide range of output capacitances.
查看全文
