[原创] Microchip HV9961+PIC16F15313恒流控制LED驱动器解决方案
关键词:电源管理 LED驱动器 HV9961
时间:2020-04-09 11:14:22       来源:中电网
Microchip公司的HV9961是平均电流模式恒流控制LED驱动器集成电路,工作在恒定关断时间模式.和HV9910B不同,该器件不会出现峰值到平均值误差.这就大大改善精度和LED电流的输入电压和负载调整率,不需要回路补偿或高边电流检测输出LED电流精确度为±3%. HV9961工作电压为8V-450V,具有PWM调光,输入为外部控制的TTL兼容信号.此外,输出电流可进行编程.工作温度-40℃ 到 125℃.主要用在DC/DC或AC/DC LED驱动器,LCD显示器的LED背景光驱动器,通用恒流源,LED标语和显示,建筑物和装饰LED照明以及LED街灯照明.中电网为您整理如下详细资料,本文介绍了HV9961主要特性,功能框图和典型应用电路图,全特性8/14引脚MCU PIC16(L)F15313/23主要特性,框图以及蓝牙白光-彩色-混合LED驱动器参考设计主要特性,框图,LED驱动板和LED负载板的电路图和材料清单,PCB设计图.
The HV9961 is an Average-Current mode constant-current control LED driver IC operating in a constant Off-time mode. Unlike the HV9910B, this control IC does not produce a peak-to-average error. This greatly improves accuracy as well as the line and load regulations of the LED current without any need for loop compensation or high-side current sensing. Its output LED current accuracy is ±3%.
The IC is equipped with a current limit comparator for Hiccup mode output short-circuit protection.
The HV9961 can be powered from an 8V–450V supply. It has a PWM dimming input that accepts an external control TTL-compatible signal. In addition, the output current can be programmed by an internal 275 mV reference or controlled externally through a 0V–..
查看全文
