[原创] ADI LT8228 100V双向电压或电流调节解决方案
关键词:电源管理 DC/DC转换器 LT8228
时间:2020-03-17 10:47:39       来源:中电网
ADI公司的LT8228是100V双向电压或电流同步调节器,具有反向电源,反向电流和故障保护功能,–60V 输入和输出负压保护,双向浪涌电流限制和升压输出短路保护以及开关 MOSFET 短路检测和保护,高达 100V 的宽输入和输出电压范围和10V 栅极驱动,具有广泛的自检,诊断和故障报告功能,可编程的固定或可同步开关频率从80kHz 至 600kHz,可编程软启动和动态电流限制.在整个温度范围内反馈电压容差为 ±1.0%.主要用在工业,汽车,医疗,军事和航空电子设备应用中需要 N+1 冗余或其他保护的高可靠性系统.中电网为您整理如下详细资料,本文介绍了LTR8228主要特性,框图,以及多种应用电路,以及演示板DC2351A主要特性,电路图,材料清单和PCB设计图.
The LTR8228 is a 100V bidirectional constant-current orconstant-voltage synchronous buck or boost controllerwith independent compensation network. The direction ofthe power flow is automatically determined by the LT8228or externally controlled. The input and output protectionMOSFETs protect against negative voltages, controlinrush currents and provide isolation between terminalsunder fault conditions such as switching MOSFET shorts.
In buck mode, the protection MOSFETs at the V1 terminalprevents reverse current. In boost mode, the sameMOSFETs regulate the output inrush current and protectsitself with an adjustable timer circuit breaker.
查看全文
