[原创] Allegro ARG81800超低静态电流1A同步降压稳压器解决方案
关键词:电源管理 稳压器 DC/DC转换器 ARG81800
时间:2020-02-12 11:39:20       来源:中电网
Allegro公司的ARG81800是超低静态电流宽输入1A同步降压稳压器,包括所有控制和保护电路, PWM稳压器输出电压精度±1.5%,在非常轻负载消耗最小的电流,有两个版本:500mA和1A.所以对于更低电流的系统,物理尺寸和功率元件可优化,以降低PCB面积和节省成本.PWM开关频率可编程,以平衡效率,元件尺寸和EMC性能.器件满足汽车AEC-Q100规范.输入工作电压3.5V到36V,经受浪涌电压到40V,低功耗(LP)模式在3.3V或5.0V VOUT时仅消耗8 μA, AUTO模式基于负载电流在PWM和LP模式自动转换.可编PWM频率(fSW)为250 kHz 到 2.4 MHz,工作温度范围‒40°C到 150°C内可调输出范围±1.5%精度.主要用在信息娱乐设备,导航系统,仪表盘,音频系统,ADAS应用,电池供电的系统,工业系统,网络和通信,家庭音响和HVAC系统.本文介绍了ARG81800主要特性和优势, 功能框图和应用框图,多种应用电路和两种参考设计及其材料清单,以及ALLEGRO ARG81800演示板通用指标,电路图,材料清单和PCB设计图.
The ARG81800 includes all the control and protection circuitry to produce a PWM regulator with ±1.5% output voltage accuracy, with ultralow quiescent current to enable “keepalive” supply operation with minimal current draw from the supply during very light load regulation. There are two versions of the ARG81800 available, 500 mA and 1 A, so the physical size of the power components can be optimized for lower current systems, thus reducing PCB area and saving cost. PWM switching frequency can be programmed over a wide range to balance efficiency, component sizing, and EMC performance. If VIN decays and the duty cycle reaches its maximum, the ARG81800 will automatically fold back its PWM frequency to extend the duty cycle and maintain VOUT.
The ARG81800 employs Low-Power (LP) mode to maintain the output voltage at no load or very light load conditions while drawing only micro-amps from VIN. The ARG81800 includes a PWM/AUTO control pin so the system can dynamically force either PWM or AUTO mode by setting this pin high or low, respectively.
If the SYNCIN pin is driven by an external clock, the ARG81800 will be forced into PWM mode and synchronize to the incoming clock. The ARG81800 adds frequency dithering to the SYNCIN clock to reduce EMI/EMC. The ARG81800 provides a CLKOUT pin so “downstream” regulators can be easily interleaved and dithered via their synchronization inputs.
ARG81800主要特性和优势:
Automotive AEC-Q100 qualified
Input operating voltage range: 3.5 to 36 V Withstands surge voltages to 40 V for load dump
Low-Power (LP) mode—draws just 8 μA from VIN while maintaining 3.3 or 5.0 VOUT
AUTO mode allows automatic transition between PWM and LP mode based on load current
Programmable PWM frequency (fSW): 250 kHz to 2.4 MHz
PWM frequency dithering and controlled switch node slew rate reduce EMI/EMC signature
CLKOUT allows interleaving and dithering of “downstream” regulators using their synchronization inputs
Interleaving minimizes input filter capacitor requirement and improves EMI/EMC performance
Synchronization of PWM frequency to external clock on SYNCIN pin
Adjustable output voltage: ±1.5% accuracy over operating temperature range (‒40℃ to 150℃)
Maximized duty cycle at low VIN improves dropout
Soft recovery from dropout condition
Adjustable soft-start time controls inrush current to accommodate a wide range of output capacitances
External compensation provides flexibility to tune the system for maximum stability or fast transient response
ARG81800应用:
Infotainment
Navigation Systems
Instrument Clusters
Audio Systems
ADAS Applications
Battery Powered Systems
Industrial Systems
Network and Telecom
Home Audio
HVAC Systems
图1. ARG81800功能框图
图2. ARG81800典型应用框图
图3. ARG81800主-跟随器配置图
图4. ARG81800 PCB布局以最小化电磁辐射
图5. ARG81800应用电路:3.3V/1A带输入EMI滤波器的降压稳压器
图6. ARG81800参考设计1:AUTO模式带CLKOUT使能, VIN = 3.5-36 V, VOUT = 3.3 V, IOUT = 0 - 1.0 A, fSW = 2.15 MHz
参考设计1推荐材料清单:
图7. ARG81800参考设计2:强迫PWM模式带CLKOUT不能, VIN = 3.5-36 V, VOUT =5.0 V, IOUT = 0 – 0.5 A, fSW = 400 kHz
参考设计2推荐材料清单:
图8. ALLEGRO ARG81800演示板外形图
演示板通用指标:
图9. ALLEGRO ARG81800演示板电路图
ALLEGRO ARG81800演示板材料清单:
图10. ALLEGRO ARG81800演示板PCB设计图:顶层
图11. ALLEGRO ARG81800演示板PCB设计图:顶层丝印
图12. ALLEGRO ARG81800演示板PCB设计图:底层
图13. ALLEGRO ARG81800演示板PCB设计图:底层铜
图14. ALLEGRO ARG81800演示板PCB设计图:顶层丝印
图15. ALLEGRO ARG81800演示板PCB设计图:底层丝印
详情请见:
https://www.allegromicro.com/en/products/regulate/regulators/single-output-regulators/arg81800
ARG81800-Datasheet.pdf
ARG81800-Eval-Board-User-Manual.pdf
