[原创] TI UCC21750单路高达1700V SiC和IGBT栅极驱动方案
关键词:电源管理 SiC IGBT 栅极驱动 UCC21750
时间:2019-08-29 13:26:01       来源:中电网
TI公司的ucc21750是设计用于1700V SiC MOSFET和IGBT单路隔离的栅极驱动器,具有先进的保护特性,业界最好的动态性能和鲁棒性以及高达±10-A峰值源电流和沉电流.输入和输出的隔离采用SiO2电容隔离技术,支持高达1.5-kVRMS工作电压,2.8-kVPK抗浪涌和大于40年的隔离寿命,以及部件和部件间低差别和>150V/ns的共模噪音抑制(CMTI).
UCC21750包括最新的保护特性如快速过流和短路检测,支持并联电流检测,故障报告,有源米勒钳位,输入和输出边电源UVLO,以优化SiC和IGBT开关性能和鲁棒性. M传感器的隔离模拟能用来温度或电压检测,进一步增加了驱动器的多样功能,从而简化了系统摄,尺寸和成本.工作温度–40°C 到125°C,主要用EV的牵引逆变器,板上充电器和DC充电站,工业马达驱动,服务器,通信和工业电源以及不间断电源(UPS).本文介绍了UCC21750主要特性,功能框图,典型应用电路图以及评估模块UCC21732QDWEVM-025主要特性,电指标,框图,电路图和各种测试建立图,材料清单和PCB设计图.
The UCC21750 is a galvanic isolated single channelgate drivers designed for up to 1700V SiC MOSFETsand IGBTs with advanced protection features, bestin-class dynamic performance and robustness.UCC21750 has up to ±10-A peak source and sinkcurrent.
The input side is isolated from the output side withSiO2 capacitive isolation technology, supporting up to1.5-kVRMS working voltage, 12.8-kVPK surge immunitywith longer than 40 years Isolation barrier life, as wellas providing low part-to-part skew, >150V/nscommon mode noise immunity (CMTI).
The UCC21750 includes the state-of-art protectionfeatures, such as fast overcurrent and short circuitdetection, shunt current sensing support, faultreporting, active miller clamp, input and output sidepower supply UVLO to optimize SiC and IGBTswitching behavior and robustness. The isolatedanalog to PWM sensor can be utilized for easiertemperature or voltage sensing, further increasing thedrivers’versatility and simplifying the system designeffort, size and cost.
UCC21750主要特性:
• Single channel SiC/IGBT isolated gate driver
• SiC MOSFETs and IGBTs up to 1700 V
• 33-V maximum output drive voltage (VDD-COM)
• Split outputs with ±10-A peak drive current
• 150-V/ns min. CMTI
• DESAT – monitor VCE, VDS while PWM is ON
– Response time: 200ns
• Active miller clamp
– 4-A internal active miller clamp
• Soft turn-off when fault happen
– Soft turn-off 400 mA
• Isolated analog sensor with PWM output for
– Temperature sense with NTC or thermal diode
– High voltage DC-link or phase voltage
• Alarm FLT on over current and reset fromRST/EN
• Fast enable/disable response on RST/EN
• Reject noise transient and pulse on input pins
• UVLO with power good on RDY
– VDD UVLO 12 V
• Inputs/outputs with over/under-shoot immunity
• Small propagation delay and pulse/part skew
• Operating temperature range –40°C to 125°C
• Safety-related certifications (planned):
– 8000-VPK VIOTM and 2121-VPK VIORMReinforced Isolation per DIN V VDE V 0884-11(VDE V 0884-11): 2017-01
– 5700-VRMS Isolation for 1 Minute per UL1577
UCC21750应用:
• Traction inverter for EVs
• On-board charger and dc charging station
• Industrial motor drives
• Server, telecom, and industrial power supplies
• Uninterruptible power supplies (UPS)
图1.UCC21750功能框图
图2.UCC21750典型应用电路图
UCC217XX Family Driving and Protecting SiC and IGBT Power Modules and Transistors
This User ’s Guide describes the characteristics, operation and use of the UCC21732QDWEVM-025Evaluation Module (EVM). This TI EVM provides driving and protection for popular Silicon Carbide (SiC)MOSFETs and Si IGBTs both in discrete and Power Module implementations. The EVM is using featurerich isolated driver device UCC21732 that is part of family of UCC217XX drivers. A complete schematicdiagram, printed-circuit board layouts, and bill of materials are included in this document.
The UCC217XXQDWEVM-025 is a compact, single channel isolated gate driver board providing drive,bias voltages, protection and diagnostic needed for SiC MOSFET and Si IGBT Power Modules housed in150 x 62 x 17 mm and 106 x 62 x 30 mm packages. The board can be set for UCC21710, UCC21732 orUCC21750 drivers of the same UCC217XX family This TI EVM is based on 5.7-kVrms reinforced isolationdrivers UCC217XX in SOIC-16DW package with 8.0 mm creepage and clearance. The EVM includesSN6505B based isolated DC-DC transformer bias supplies. Isolated temperature and input rail monitoringis provided using analog sensor and PWM output integrated into UCC217XX. Compact form factor 62 x 48x 6.6 mm allows direct connection of two boards to drive and protect standard half-bridge modules with upto 1700 V rail.
评估模块UCC21732QDWEVM-025主要特性:
• 10-A peak split sink/source drive current for fast turn ON and turn OFF time
• 2-W bias supply with UVLO and OVLO protection set by default at 4.5 V to 5.5 V
• Drive voltages by default are 17/-5 V with single 5-V input supply
• Drive voltages can be also programmed independently from 11 V to 19 V for turn ON and from -3.3 Vto -6 V for turn OFF by using two input supplies from 3.3 V to 5.5 V
• Noise-immune design with CMTI >150 V/ns
• 5.7-kVrms reinforced isolation
• OC short-circuit shunt resistor sensing with two-level (UCC21732) or single level (UCC21710) softturn-OFF protection
• OC signal setting either for positive or negative polarity
• DeSat short-circuit sensing for UCC21750
• Active Miller clamp using external FET (UCC21732) or internal (UCC21710)
• Output short circuit clamp
• Fault feedback with reset
• Isolated temperature and input rail monitoring
评估模块UCC21732QDWEVM-025应用:
• Solar inverters
• Motor drives
• HEV/EV chargers
评估模块UCC21732QDWEVM-025电指标:
图3.评估模块UCC21732QDWEVM-025框图
图4.评估模块UCC21732QDWEVM-025功能区块图
图5.评估模块UCC21732QDWEVM-025顶视图
图6.评估模块UCC21732QDWEVM-025底视图
图7.评估模块UCC21732QDWEVM-025主要功能框图
图8. UCC21732, UCC21710 and UCC21750简化框图
图9.评估模块UCC21732QDWEVM-025加电和偏压电源电压测试建立图
图10.评估模块UCC21732QDWEVM-025输入和输出开关波形测试建立图
图11.评估模块UCC21732QDWEVM-025过流和短路软关断OFF测试建立图
图12.评估模块UCC21732QDWEVM-025隔离模拟输入和输出测试建立图
图13.评估模块UCC21732QDWEVM-025电路图
评估模块UCC21732QDWEVM-02材料清单:
图14.评估模块UCC21732QDWEVM-025 PCB设计图(1)
图15.评估模块UCC21732QDWEVM-025 PCB设计图(2)
图16.评估模块UCC21732QDWEVM-025和标准106mm半桥模块连接图
图17.评估模块UCC21732QDWEVM-025和标准150mm半桥模块连接图
图18.评估模块UCC21732QDWEVM-025 PCB设计图(3)
图19.评估模块UCC21732QDWEVM-025 PCB设计图(4)
图20.评估模块UCC21732QDWEVM-025 PCB设计图(5)
图21.评估模块UCC21732QDWEVM-025 PCB设计图(6)
详情请见:
http://www.ti.com/lit/ds/symlink/ucc21750.pdf
http://www.ti.com/lit/ug/sluubx2a/sluubx2a.pdf
ucc21750.pdf
sluubx2a.pdf
