¹Ø¼ü´Ê£ºÎïÁªÍø(IoT) ÖÇÄܹ¤Òµ ÖÇÄÜ¼Ò¾Ó ÖÇÄܳÇÊÐ EdgeLock SE050
ʱ¼ä£º2019-06-24 10:59:40 À´Ô´£ºÖеçÍø
NXP¹«Ë¾µÄEdgeLock SE050ÊÇËæÊ±¿ÉÓõÄÎïÁªÍø(IoT)°²È«Ôª¼þ½â¾ö·½°¸,Ëü»ùÓÚNXP¹«Ë¾µÄÕûÌ尲ȫ¼Ü¹¹3.0™,ÄܶԸ÷ÖÖ°²È«ÍþвÌṩ°²È«ºÍÓÐЧ±£»¤,¶ø°²È«Ð§ÂʲâÁ¿ÓÉͨÓÃ×¼ÔòEAL6+Ö¤ÊéÀ´Ö¤Ã÷.SE050»ùÓÚ×ÛºÏJavacard²Ù×÷ϵͳºÍÓ¦ÓóÌÐò¿ÉÍêÈ«×ÔÖ÷µØ²Ù×÷,Ö±½ÓÄÚ´æ´æÈ¡½öÓÃÓ¦ÓóÌÐòµÄ¹Ì¶¨¹¦ÄܾÍÄÜʵÏÖ.¶ø´æ´¢Æ÷µÄÄÚÈÝÍêÈ«ºÍÖ÷ϵͳ¸ôÀë.Æ÷¼þÓжà¸öÂß¼ºÍÎïÀí±£»¤²ã,°üÀ¨½ðÊôÆÁ±Î,¶Ëµ½¶Ë¼ÓÃÜ,´æ´¢Æ÷¼ÓÃܺʹܸÄÕì²â,Ö§³ÖRSAºÍECC·Ç¶Ô³Æ¼ÓÃÜËã·¨,δÀ´ÑéÖ¤ÇúÏߺ͸߼ü³¤¶ÈÈçÄÔ³Ø(Brainpool),°®µÂ»ª×È(Edwards)ºÍÃɸçÂíÀû(Montgomery)ÇúÏß,Ö§³ÖÓÃÓÚ¼ÓÃܺͽâÃܵÄAESºÍDES¶Ô³Æ¼ÓÃÜËã·¨,HMAC,CMAC,SHA-1,SHA-224/256/ 384/512ÔËÐÐ,Ö÷ÒªÅÉÉú¹¦Äܵĸ÷ÖÐÖÖÑ¡Ôñ°üÀ¨HKDF,MIFARE KDFºÍPRF(TLSPSK),²ÉÓÃÏȽøµÄ40nm¹è¹¤ÒÕ,¹¤×÷ζÈ-40¡æµ½ +105¡æ,Ö÷ÒªÓÃÔÚÖÇÄܹ¤Òµ,ÖÇÄܼҾÓ,ÖÇÄܳÇÊкÍÖÇÄܹ©Ó¦Á´.±¾ÎĽéÉÜÁËSE050Ö÷ÒªÓÅÊÆºÍ½â¾ö·½°¸¿òͼ,¹¦ÄÜ¿òͼÒÔ¼°ÆÀ¹À°åOM-SE050ARDÖ÷ÒªÌØÐԺ͵ç·ͼ.
The SE050 is a ready-to-use IoT secure element solution. It provides a root of trust at the IC level and it gives an IoT system state-of-the-art, edge-to-cloud security capability right¡¡out of the box.
SE050 allows for securely storing and provisioning credentials and performing¡¡cryptographic operations for security critical communication and control functions. SE050¡¡is versatile in IoT security use cases such as secure connection to public/private clouds,¡¡device-to-device authentication or protection of sensor data.
SE050 has an independent Common Criteria EAL 6+ security certification up to OS level¡¡and supports both RSA & ECC asymmetric cryptographic al..
·ÖÏíµ½£º
²ÂÄãϲ»¶
