[原创] ST L9945八路12V和24V系统全配置高-低边MOSFET预驱动解决方案
关键词:汽车电子 12V系统 24V系统 MOSFET驱动器 L9945
时间:2019-05-30 10:41:23       来源:中电网
ST公司的L9945是八路MOSFET预驱动器,可配置成用于低边,高边,峰值和保持以及H桥负载的控制,设计用于12V(客车)和24V(商用车)电池系统.所有输出是PWM控制的,其中6个输出能安全驱动相关载荷,一个能激励需要专用使能引脚(EN6)的相关载荷.L9945提供控制两个单独H桥的功能,还能驱动多达两个需要”峰值保持”控制的负载.每个输出提供全部的诊断信息如对电池短路,对地短路和负载开路.而每个输出状态能不断通过专用SPI寄存器进行监测.器件满足AEC-Q100规范,3.3V和5V逻辑兼容I/O,工作电池电压3.8V到36V,工作的VDD电压4.5V-5.5V,L9945中的10位ADC通过SPI对电池和芯片温度进行测量.主要用在汽车电子.本文介绍了L9945主要特性,框图以及评估板EVAL-L9945及其应用框图,配置框图,电路图,材料清单和PCB设计图.
The L9945 is an 8-channel MOSFET pre-driver configurable for low-side, high-side, peak and hold and H-Bridge load control. It is designed to comply with the requirements of 12 V (passenger vehicle) and 24 V (commercial vehicle) battery systems.
All outputs can be PWM controlled. Six outputs are capable of driving safety relevant loads. One output can be dedicated to the actuation of safety relevant loads requiring a dedicated enable pin (EN6).
The device offers the possibility of controlling two independent H-Bridges.
The device can also drive up to two loads requiring "peak & hold" control strategy.
The driver outputs are protected against short circuit condition.
The device protects the external MOS in case of an overcurrent event...
查看全文
