[原创] Cypress EZ-PD CCG3PAUSB Type-C端口控制器解决方案
关键词:Arm Cortex-M0 MCU USB Type-C PD 电源管理 汽车充电器 充电宝
时间:2019-05-28 11:57:26       来源:中电网
Cypress公司的EZ-PD™ CCG3PA是高度集成的USB Type-C端口控制器,和最新的USB Type-C和PD标准兼容,目标应用在PC电源适配器,移动充电器,汽车充电器和充电宝(power bank).CCG3PA采用Cypress所有权的M0S8和32位Arm® Cortex™-M0处理器,以及64KB闪存,完整的Type-C USB-PD收发器,所有Type-C端口需要的端电阻,用于电压(VBUS)稳压器和系统级ESD保护的集成反馈控制电路.工作电压3.0-V到24.5-V,工作温度3.0-V to到24.5-V.本文介绍了EZ-PD™ CCG3PA主要特性,逻辑框图和内部框图,多种应用框图,评估板CY4532 EZ-PD™ CCG3PA EVK主要特性,及其主板和电源板的框图,电路图,材料清单和PCB设计图.
EZ-PD™ CCG3PA is Cypress’ highly integrated USB Type-C port controller that complies with the latest USB Type-C and PDstandards and is targeted for PC power adapters, mobile chargers, car chargers, and power bank applications. In such applications,CCG3PA provides additional functionalities and BOM integration advantages. CCG3PA uses Cypress’ proprietary M0S8 technologywith a 32-bit Arm® Cortex™-M0 processor, 64-KB flash, a complete Type-C USB-PD transceiver, all termination resistors required for a Type-C port, an integrated feedback control circuitry for voltage (VBUS) regulation and system-level ESD protection. It is availablein 24-pin QFN and 16-pin SOIC packages.
EZ-PD™ CCG3PA主要特性:
Type-C Support and USB-PD Support..
查看全文
