[原创] Diodes AP72200高效同步DC-DC升降压转换器解决方案
关键词:电源管理 DC/DC转换器 AP72200
时间:2019-04-28 12:06:18       来源:中电网
Diodes公司的AP72200是大电流同步DC/DC升降压转换器,具有高效率,极好的瞬态响应和大DC输出精度.它采用四开关H桥配置,支持降压和升压工作,升/降压提供大于2A的输出电流.AP72200具有I2C兼容两线串行接口,包括双向串行数据线,SDA和串行时钟线,SCL.支持SCL时钟速率高达3.4MHz;此外,还具有UVLO,OTP和OCP保护电路.输入电压VIN从2.3V到5.5V,输出电压从2.6V-5.14V,连续输出电流2A,当VOUT=3.4V和 VIN>2.9V时效率高达97%.主要用在智能手机,平板电脑和其它手持设备.本文介绍了AP72200主要特性,功能框图,典型应用以及评估板AP72200-EVM主要特性,电路图,材料清单和PCB设计图.
The AP72200 is a high-current synchronous buck-boost converter providing high efficiency, excellent transient response, and high DC output accuracy. The targeted applications are smartphones, tablets, and other handheld devices. The AP72200 utilizes a four-switch H-bridge configuration to support buck and boost operation. The buck-boost provides at least 2A output current.
The current control scheme handles wide input/output voltage ratios and provides low external component count with outstanding performance in line/load transient response and seamless transition between buck and boost modes.
The AP72200 features I2C compatible, two-wire serial interface consisting of a bidirectional serial-data line, SDA, and a serial-clock line, SCL. It supports SCL clock rates up to 3.4MHz.
查看全文
