[原创] Cypress PSOC 4700S电感检测解决方案
关键词:Arm Cortex-M0+ MCU PSoC 消费类电子 汽车电子 工业领域 PSOC 4700S
时间:2019-03-06 11:04:05       来源:中电网
cypress公司的PSOC 4700S是可编程片上系统(PSoC),集成了ARM® Cortex®-M0+ CPU,包括了可编程和可配置的模拟和数字区块,并具有灵活的自动走线.广泛支持编程,测试,调试,以及跟踪硬件和固件.32位MCU子系统48MHz,多达32KB闪存和多达4KB SRAM,可进行电容检测,电感检测支持16个传感器,主要用在消费类电子,汽车电子,工业领域.本文介绍了PSOC 4700S主要特性,框图,以及PSoC® 4700S电感检测评估板CY8CKIT-148主要特性,框图和电路图.
PSoC® 4 is a scalable and reconfigurable platform architecture for a family of programmable embedded system controllers with anArm® Cortex®-M0+ CPU. It combines programmable and reconfigurable analog and digital blocks with flexible automatic routing. ThePSoC 4700S product family, based on this platform, is the industry’s first microcontroller with inductive sensing and capacitive sensingtechnology in a single chip. The inductive sensing (MagSense™) technology enables sensing of metal objects and industry’s leadingcapacitive sensing (CapSense®) technology enables sensing of non-metallic objects.
PSoC 4700S devices include extensive support forprogramming, testing, debugging, and tracing both hardwareand firmware.
The Arm Serial-Wire Debug (SWD) interface supports allprogramming and debug features of the device.
Complete debug-on-chip functionality enables full-devicedebugging in the final system using the standard productiondevice. It does not require special interfaces, debugging pods,simulators, or emulators. Only the standard programmingconnections are required to fully support debug.
The PSoC Creator IDE provides fully integrated programmingand debug support for the PSoC 4700S devices. The SWDinterface is fully compatible with industry-standard third-partytools. The PSoC 4700S family provides a level of security notpossible with multi-chip application solutions or withmicrocontrollers. It has the following advantages:
■ Allows disabling of debug features
■ Robust flash protection
■ Allows customer-proprietary functionality to be implemented inon-chip programmable blocks
The debug circuits are enabled by default and can be disabledin firmware. If they are not enabled, the only way to re-enablethem is to erase the entire device, clear flash protection, andreprogram the device with new firmware that enables debugging.
Thus firmware control of debugging cannot be over-riddenwithout erasing the firmware thus providing security.
Additionally, all device interfaces can be permanently disabled(device security) for applications concerned about phishingattacks due to a maliciously reprogrammed device or attempts todefeat security by starting and interrupting flash programmingsequences. All programming, debug, and test interfaces aredisabled when maximum device security is enabled.Therefore,PSoC 4700S, with device security enabled, may not be returnedfor failure analysis. This is a trade-off the PSoC 4700S allows thecustomer to make
PSOC 4700S主要特性:
32-bit MCU Subsystem
■ 48-MHz Arm Cortex-M0+ CPU
■ Up to 32 KB of flash with Read Accelerator
■ Up to 4 KB of SRAM
Inductive Sensing
■ Cypress inductive sensing provides superior noise immunity
■ Can reliably detect metal deflection under 190 nm
■ MagSense software component automatically calibrates thesolution to compensate for the manufacturing variations
■ Supports up to 16 sensors
Capacitive Sensing
■ Cypress CapSense Sigma-Delta (CSD) provides best-in-classsignal-to-noise ratio (SNR) (>5:1) and water tolerance
■ Cypress-supplied software component makes capacitivesensing design easy
■ Automatic hardware tuning (SmartSense™)
Programmable Analog
■ Single-slope 10-bit ADC function provided by Capacitancesensing block
■ Two current DACs (IDACs) for general-purpose or capacitivesensing applications on any pin
■ Two low-power comparators that operate in Deep Sleeplow-power mode
Programmable Digital
Programmable logic blocks allowing Boolean operations to beperformed on port inputs and outputs
Low-Power 1.71-V to 5.5-V Operation
■ Deep Sleep mode with operational analog and 2.5uA digitalsystem current
Serial Communication
■ Two independent run-time reconfigurable SerialCommunication Blocks (SCBs) with re-configurable I2C, SPI,or UART functionality
LCD Drive Capability
■ LCD segment drive capability on GPIOs
Timing and Pulse-Width Modulation
■ Five 16-bit timer/counter/pulse-width modulator (TCPWM)blocks
■ Center-aligned, Edge, and Pseudo-random modes
■ Comparator-based triggering of Kill signals for motor drive andother high-reliability digital logic applications
Up to 36 Programmable GPIO Pins
■ 48-pin TQFP, 24-pin QFN, and 25-ball WLCSP packages
■ Any GPIO pin can be Capacitive Sensing, analog, or digital; upto 16 pins can be used for inductive sensing.
■ Drive modes, strengths, and slew rates are programmable
PSoC Creator Design Environment
■ Integrated Development Environment (IDE) providesschematic design entry and build (with analog and digitalautomatic routing)
■ Applications Programming Interface (API) component for allfixed-function and programmable peripherals
Industry-Standard Tool Compatibility
■ After schematic entry, development can be done withArm-based industry-standard development tools
图1.PSOC 4700S框图
CY8CKIT-148 PSoC® 4700S Inductive Sensing Evaluation Kit
The PSoC 4700S Inductive Sensing Evaluation Kit is designed as an easy-to-use and inexpensiveevaluation platform. The PSoC 4700S Inductive Sensing Evaluation Kit supports the PSoC 4700Sdevice, delivering a complete system solution for a wide range of embedded applications at a verylow cost. The PSoC 4700S device is a true programmable embedded system-on chip, integratingcustom digital peripheral functions, memory, and an ARM® Cortex®-M0+ MCU on a single chip withflexible automatic routing. The programmable digital peripheral functions allow higher flexibility, infieldtuning of the design, and faster time-to-market. It is a combination of MCU with standardcommunication and timing peripherals, and a inductive sensing system with best in class performance.
The PSoC 4700S Inductive Evaluation Kit offers a complete solution for Inductive Sensing Technology with PSoC 4700S device. This kit provides a low-cost alternative to device sampleswhile providing a platform to easily develop and integrate the PSoC 4700S device into your endsystem.
电感检测评估板CY8CKIT-148主要特性:
■ Seven LEDs to provide feedback for 4700S device
■ KitProg2 Status LED and Mode switch
■ Three Inductive Sensing button coils and one Proximity coil for Inductive Sensing evaluation
■ Reset switch
■ USB Type-C Connector
■ 3.3 V operation
The CY8CKIT-148 PSoC 4700S Inductive Sensing Evaluation Kit also integrates a CypressKitProg2 that enables onboard programming, debugging, and bridging functionalities, such asUSB-UART and USB-I2C.
Kit Contents
The PSoC 4700S Inductive Sensing Evaluation Kit contains a PSoC 4700S Evaluation board,Metal Target, USB Type-A to Type-C Cable and Quick Start Guide
图2.电感检测评估板CY8CKIT-148外形图
图3.金属标识
图3.电感检测评估板CY8CKIT-148框图
图4.PSoC 4700器件(标识)电路图
图5.PSoC 5LP(KitProg2)电路图
图6.电流测量图
图7.电感检测评估板CY8CKIT-148电路图(1)
图8.电感检测评估板CY8CKIT-148电路图(2)
图9.电感检测评估板CY8CKIT-148电路图(3)
图10.电感检测评估板CY8CKIT-148电路图(4)
图11.电感检测评估板CY8CKIT-148电路图(5)
详情请见:
https://www.cypress.com/file/425791/download
https://www.cypress.com/file/427781/download
以及https://www.cypress.com/file/443866/download
https://www.cypress.com/file/427786/download
CY8CKIT-148 PSoC 4700S Inductive Sensing Evaluation Kit Firmware.zip
002-20489_PSOC_4_PSOC_4700S_FAMILY_DATASHEET_PROGRAMMABLE_SYSTEM-ON-CHIP_PSOC.pdf
CY8CKIT-148_Schematic.pdf
CY8CKIT-148_PSoC_4700S Inductive_Sensing_Evaluation_Kit_Quick_Start_Guide.pdf
CY8CKIT-148_PSoC_4700S_Inductive_Sensing_Evaluation_Kit_Guide.PDF
