[原创] Diodes AP72200大电流同步升-降压转换器解决方案
关键词:电源管理 DC/DC转换器 AP72200
时间:2019-03-01 10:45:33       来源:中电网
Diodes公司的AP72200是大电流同步升-降压转换器,采用四开关H桥配置,以支持降压和升压操作,提供至少是2A的输出电流,具有高效率,极好的瞬态特性和大DC电流输出精密度.主要用于智能手机,平板电脑和手持消费类电子设备.本文介绍了AP72200功能框图,应用电路,以及评估板AP72200-EVM主要特性,电路图,材料清单和PCB设计图.
The AP72200 is a high-current synchronous buck-boost converter providing high efficiency, excellent transient response, and high DC output accuracy. The targeted applications are smartphones, tablets, and other handheld devices. The AP72200 utilizes a four-switch H-bridge configuration to support buck and boost operation. The buck-boost provides at least 2A output current.
The current control scheme handles wide input/output voltage ratios and provides low external component count with outstanding performance in line/load transient response and seamless transition between buck and boost modes.
The AP72200 features I2C compatible, two-wire serial interface consisting of a bidirectional serial-data line, SDA, and a serial-clock line, SCL. It supports SCL clock rates up to 3.4MHz.
The AP72200 also features UVLO, OTP, and OCP to protect the circuit.
This IC is available in a small 2.125mm × 1.750mm, 20 balls WLCSP package.
AP72200应用:
• Smartphones
• Tablets
• Portable Consumer Devices
图1.AP72200功能框图
图2. AP72200应用电路
评估板AP72200-EVM
The AP72200 is a high current synchronous buck-boost converter providing high efficiency, excellent transient response and high DC output accuracy. The targeted applications are smartphones, tablets, and other handheld devices. The AP72200 utilizes a four switches H-bridge configuration to support buck and boost operation. The buck-boost provides at least 2A output current.
The AP72200 features I2C compatible, 2-wires serial interface consisting of a bidirectional serial-data line, SDA, and a serial-clock line, SCL. It supports SCL clock rates up to 3.4MHz.
This IC is available in a small 2.125x1.750mm, 20 balls WLCSP package.
评估板AP72200-EVM主要特性:
 VIN 2.3V to 5.5V
 Output Voltage range: 2.6V to 5.14V
 2A Continuous Output Current for VOUT=3.4V and VIN>2.9V Efficiency Up to 97%
 2.5MHz Switching Frequency
 I2C Interface
 Selectable MODE PFM/PWM
 Ultrasonic Operation Programmable through I2C
 Power Good Indicator with 5M Internal Pull-up
 Adjustable Overcurrent Limit
 Full Protected for Overcurrent,Short Circuit,Reverse Current Protection, Over Temperature, and UVLO
 Totally Lead-Free & Fully RoHS Compliant
 Halogen and Antimony Free.“Green” Device
评估板AP72200-EVM应用:
 Smartphones
 Tablets
 Portable Consumer Devices
图3.评估板AP72200-EVM外形图
图4.评估板AP72200-EVM电路图
评估板AP72200-EVM材料清单:
图5.评估板AP72200-EVM PCB设计图:顶层
图6.评估板AP72200-EVM PCB设计图:底层
详情请见:
https://www.diodes.com/assets/Datasheets/AP72200.pdf
https://www.diodes.com/assets/Evaluation-Boards/AP72200-EVM-Manual.pdf
AP72200.pdf
