[原创] ADI ADM3055E带信号隔离通道CAN物理层收发器解决方案
关键词:电源管理 DC/DC转换器 iCoupler isoPower ADM3055E
时间:2019-01-23 10:29:26       作者:ADI       来源:中电网
ADI公司的ADM3055E是集成了逻辑侧开关键控(OOK)信号隔离通道和isoPower® DC/DC 转换器的控制器局域网(CAN)物理层收发器,满足CAN FD规范,工作速率5Mbps或更高的12 Mbps,和ISO 11898-2: 2016标准兼容.隔离电压5 kV rms/3 kV rms,工作温度−40℃到+105℃,主要用在CANOpen,DeviceNet和其它CAN总线,工业自动化,过程控制和建筑物控制,交通和基础设备.本文介绍了ADM3055E/ADM3057E主要特性,框图,以及评估板EVAL-ADM3055EEBZ主要特性,电路图,材料清单和PCB设计图.
The ADM3055E/ADM3057E are 5 kV rms and 3 kV rms isolated controller area network (CAN) physical layer transceivers with integrated isolated dc-to-dc converters. The ADM3055E/ ADM3057E meet flexible data rate (CAN FD) requirements for operation to 5 Mbps and higher and comply with the ISO 11898-2: 2016 standard. The ADM3055E/ADM3057E are capable of supporting data rates as high as 12 Mbps.
查看全文
