[原创] Maxim MAX86150生物传感器模块流动医疗解决方案
关键词:生物传感器 心电图 MAX86150
时间:2019-01-22 11:02:00       作者:Maxim       来源:中电网
Maxim公司的MAX86150是集成了用于动医疗的心电图,脉搏血氧仪和心率监视器传感器模块,包括LED,光电检测器和具有环境光抑制的低噪音电子学,使得很容易设计流动医疗和可穿戴设备.器件工作电压1.8V,并具有用于内部LED的单独电源,和模块的通信采用I2C兼容的接口,主要用在智能手机,平板电能,可穿戴设备以及健身辅助设备.本文介绍了MAX86150主要优势和特性,简化框图和功能框图,应用电路图以及评估板MAX86150 EVK主要特性,电路图,材料清单和PCB设计图.
The MAX86150 is an integrated electrocardiogram, pulse oximeter, heart rate monitor sensor module. It includes internal LEDs, photodetector, and low-noise electronics with ambient light rejection. The MAX86150 helps ease design-in to mobile and wearable devices.
The MAX86150 operates on a 1.8V supply voltage with a separate power supply for the internal LEDs. Communication to and from the module is entirely through a standard I2C-compatible interface. The module can be shut down through software with near zero standby current, allowing the power rails to remain powered at all times.
MAX86150主要优势和特性:
Electrocardiogram (ECG) Optimized for Dry Electrode Operation
Reflective Heart Rate Monitor and Medical-Grade Pulse Oximeter
Miniature 3.3mm x 5.6mm x 1.3mm 22-pin Optical Module Optical-Grade Glass for Long-Term Optimal and Robust Performance ..
查看全文
