[原创] Allegro ACS71020电源监视解决方案
关键词:电源管理 电源监视 电流传感器 ACS71020
时间:2018-10-23 10:52:07       作者:Allegro       来源:中电网
Allegro公司的ACS71020电源监视集成电路,采用霍尔效应电流绝缘的电流传感器技术,大大地简化了任何AC/DC电源设备的功率监测.用户可编程VRMS欠压/过压引脚,1kHz带宽,电流检测从0A到90A,I2C或SPI通信,通过EEPROM寄存器进行用户编程,16位电压和电流ADC.本文介绍了ACS71020主要特性,框图和典型应用电路图以及ACS71020演示板主要元件和电路图.
The ACS71020 power monitoring IC greatly simplifies the addition of power monitoring to any AC/DC powered device. By making use of Allegro’s Hall-effect-based, galvanically isolated integrated current sensor technology, reinforced isolation can be achieved. The sensor can be powered from the same supply as the MCU, eliminating the need for multiple power supplies and digital isolation ICs.
The isolated current measurement is done by detecting the magnetic field from the integrated conductor, eliminating the need for external sense resistors, current transformers, or Rogowski coils. Two Hall plates are used for this measurement to differentially sense the field, thus eliminating errors due to stray magnetic fields. Multiple parameters like bandwidth, averaging time, and fault levels are user-programmable.
查看全文
