[原创] Avnet MiniZed单核Zynq 7Z007S入门开发方案
关键词:FPGA SoC 单核Zynq 7Z007S器件
时间:2018-09-18 10:52:49       作者:Avnet       来源:中电网
Avnet公司的MiniZed是Xilinx公司的单核Zynq 7Z007S器件的开发板,目标在具有低成本原型平台的入门级Zynq开发设计师,可使设计者开发或评估Zynq处理器子系统(PS)和可编逻辑(PL)架构.开发板具有通过USB, Wi-Fi和蓝牙进行板上连接,外设能插入两个Pmod兼容的连接器, Arduino兼容的屏蔽接口或USB 2.0主接口, JTAG电路使用一根电缆通过 USB口连接笔记本电脑,就可以使开发板运行起来.主要应用在入门级/低成本Zynq开发环境,采Wi-Fi和蓝牙的无线设计和演示,采用麦克风输入的音频信号处理,板上和外设传感器的IoT/云连接.本文介绍了MiniZed开发板主要特性和所支持特性,框图和拓扑图,电路图,材料清单和PCB设计图.
MiniZed™ is a single-core Zynq 7Z007S development board.With the advent of the latest cost-optimized portfolio fromXilinx, this board targets entry-level Zynq developers witha low-cost prototyping platform.
This compact design features on-board connectivity through USB, Wi-Fi andBluetooth. Peripherals can be plugged into dual Pmod-compatible connectors,the Arduino-compatible shield interface or the USB 2.0 host interface. JTAGcircuitry is incorporated onto the MiniZed base board, so with a single micro-USB cable to your laptop you are already up and running. User LED’s, a buttonand a switch allow for a physical board interface.
查看全文
