[原创] Cypress PSoC 63系列BLE 5.0兼容无线连接解决方案
关键词:ARM Cortex-M4F MCU ARM Cortex M0+ MCU BLE 5.0 PSoC
时间:2018-02-20 10:10:10       作者:Cypress       来源:中电网
Cypress公司的PSoC 63系列是集成了ARM®Cortex™ CPU的可升级和可配置的嵌入系统控制器,采用超低功耗40nm技术,组合了双核微控制器,低功耗闪存,数字可编逻辑以及高性能模数和数模转换器,低功耗比较器,标准通信和定时外设,可以提供和BLE 5.0兼容的无线连接,主要用在物联网(IoT)领域.本文介绍了PSoC 63系列主要特性,系列框图以及PSoC® 6 BLE Pioneer套件主要特性,PSoC® 6 BLE Pioneer板框图,电路图,材料清单和PCB设计图.
PSoC® is a scalable and reconfigurable platform architecture for a family of programmable embedded system controllers with ARM®Cortex™ CPUs (single and multi-core). The PSoC 63 product family, based on an ultra low-power 40-nm platform, is a combinationof a dual-core microcontroller with low-power Flash technology and digital programmable logic, high-performance analog-to-digitaland digital-to-analog conversion, low-power comparators, and standard communication and timing peripherals. The PSoC 63 familyprovides wireless connectivity with BLE 5.0 compliance.
PSoC 63系列主要特性:
32-bit Dual Core CPU Subsystem
■ 150-MHz ARM Cortex-M4F CPU with single-cycle multiply(Floating Point and Memory Protection Unit)
■ 100-MHz Cortex M0+ CPU
■ User-selectable core logic operation at either 1.1 V or 0.9 V
■ Inter-processor communication supported in hardware..
查看全文
