[原创] Linear LTM4651 58V 24W反相输出μModule稳压方案
关键词:电源管理 DC/DC转换器 LTM4651
时间:2017-11-08 09:48:25       作者:Linear       来源:中电网
Linear公司的LTM4651是EN55022B兼容58V/24W反相输出DC/DC μModule稳压器,输入电压3.6V - 58V,输出VOUT在-5V到-26.5V之间,输出电流高达4A,开关频率在250kHz - 3MHz,主要用在航空电子设备,工业控制和测试设备厂,视频,图像和仪表,48V通信和网络电源,RF系统.本文介绍了LTM4651主要特性,框图,测试电路和应用电路,以及演示板DC2328A主要特性,电路图和材料清单.
The LTMR4651 is an ultralow noise, 58V, 24W DC/DCμModuleR inverting topology regulator. It regulates a negativeoutput voltage (VOUT–) from a positive input supplyvoltage (VIN), and is designed to meet the radiated emissionsrequirements of EN55022. Conducted emission requirementscan be met by adding standard filter components.Included in the package are the switching controller, powerMOSFETs, inductor, filters and support components.
The LTM4651 can regulate VOUT–to a value between–0.5V and–26.5V, provided that its input and outputvoltages adhere to the safe operating area criteria of theLTM4651: VIN + |VOUT–|≤ 58V. A switching frequencyrange of 250kHz to 3MHz is supported (400kHz default)and the module can synchronize to an external clock.
查看全文
