[原创] TI AMIC110 32位Sitara ARM MCU开发方案
关键词:ARM Cortex-A8 MCU 工业控制 工业通信
时间:2017-09-30 09:26:22       作者:TI       来源:中电网
TI公司的AMIC110是多协议可编程工业通信处理器,为大多数工业以太网和现场总线通信提供随时可用的解决方案.器件基于ARM Cortex-A8处理器,具有可选择外设和工业接口,支持高级操作系统(HLOS),Linux®和TI-RTOS以及其它RTOS.器件CPU工作频率300MHz,具有NEON™ SIMD协处理器,集成了32KB L1指令和32KB数据缓存,256KB L2高速缓存,176KB引导ROM,64KB专用RAM,主要用在工业通信,连接工业设备和底板I/O.本文介绍了AMIC110主要特性,功能框图,以及工业通信引擎AMIC110 ICE主要特性,框图,电路图,材料清单和PCB元件布局图.
The AMIC110 device is a multiprotocol programmable industrial communications processor providingready-to-use solutions for most industrial Ethernet and fieldbus communications slaves, as well as somemasters. The device is based on the ARM Cortex-A8 processor, peripherals, and industrial interfaceoptions. The device supports high-level operating systems (HLOS). Linux® and TI-RTOS are available freeof charge from TI. Other RTOS are also offered by TI ecosystem partners. The AMIC110 microprocessoris an ideal companion communications chip to the C2000 family of microcontrollers for connected drives.
查看全文
