[原创] ST STGIPQ3H60T-HZSLLIMM 600V IPM模块解决方案
关键词:工业控制 马达控制 IPM IGBT SLLIMM
时间:2017-09-29 09:36:13       作者:ST        来源:中电网
ST公司的STGIPQ3H60T-HZ是小型低损耗智能模块(SLLIMM) nano第二代IPM,600V/3A 3相IGBT反相桥,是紧凑高性能AC马达驱动器,包括6个改进的IGBT和续流二极管,三个用来栅极驱动的半桥HVIC,具有低电磁干扰(EMI)特性和最佳开关速度.3.3 V, 5 V, 15 V TTL/CMOS输入,高达±2 kV ESD保护(HBM C = 100 pF, R = 1.5 kΩ),主要用在3相马达驱动逆变器,洗碗机,冰箱压缩机,加热系统,空调风扇,排水和再循环泵.本文介绍了STGIPQ3H60T-HZ主要特性和内部框图,以及马达控制电源板STEVAL-IPMNG3Q主要特性,电路图和材料清单.
This second series of SLLIMM (small low-loss intelligent molded module) nano provides a compact, high performance AC motor drive in a simple, rugged design. It is composed of six improved IGBTs with freewheeling diodes and three half-bridge HVICs for gate driving, providing low electromagnetic interference (EMI) characteristics with optimized switching speed. The package is designed to allow a better and more easily screwed-on heatsink and is optimized for thermal performance and compactness in built-in motor applications or other low power applications where assembly space is limited. This IPM includes a completely uncommitted operational amplifier and a comparator that can be used to design a fast and efficient protection circuit. SLLIMM™ is a trademark of STMicroelectronics.
STGIPQ3H60T-HZ主要特性:
查看全文
