[原创] Cypress EZ-PD CCG3PAUSB Type-C端口控制方案
关键词:32-bit ARM Cortex-M0 MCU 电源管理 充电器 USB Type-C USB-PD
时间:2017-09-07 10:18:15       作者:Cypress       来源:中电网
Cypress公司的EZ-PD™ CCG3PA是高度集成的USB Type-C端口控制器,和最新的USB Type-C和PD标准兼容.器件采用Cypress公司的M0S8技术和32位ARM® Cortex™-M0处理器,64KB闪存,完整的Type-C USB-PD收发器,Type-C端口所需的所有端电阻,用于电压(VBUS)稳压的反馈控制电路和系统级ESD保护.主要用在PC电源适配器,移动充电器,汽车充电器和电源柜应用.本文介绍了EZ-PD™ CCG3PA主要特性,逻辑框图和内部框图,多种应用电路以及评估板CY4532 EZ-PD CCG3PA EVK(主板和电源板)主要特性,电路图,材料清单和PCB设计图.
EZ-PD™ CCG3PA is Cypress’s highly integrated USB Type-C port controller that complies with the latest USB Type-C and PDstandards and is targeted for PC power adapters, mobile chargers, car chargers, and power bank applications. In such applications,CCG3PA provides additional functionalities and BOM integration advantages. CCG3PA uses Cypress’s proprietary M0S8 technologywith a 32-bit ARM® Cortex™-M0 processor, 64KB flash, a complete Type-C USB-PD transceiver, all termination resistors required fora Type-C port, an integrated feedback control circuitry for voltage (VBUS) regulation and system-level ESD protection. It is availablein 24-pin QFN and 16-pin SOIC packages.
EZ-PD™ CCG3PA主要特性:
Type-C Support and USB-PD Support..
查看全文
