[原创] Linear LTC5552 3-20GHz微波混频器解决方案
关键词:无线通信 微波收发器 5G宽带无线接入 测试设备 LTC5552
时间:2017-08-25 10:07:03       作者:Linear       来源:中电网
Linear公司的LTC5552是宽带DC-6GHz IF的3-20GHz高性能微波双平衡无源混频器,可用作频率下变换或上变换.器件具有高IIP3,在10GHz为22.5dBm,17GHz为18.3dBm,10GHz的变换损耗8dB,工作电源3.3V/132mA,主要用在5G宽带无线接入,微波收发器,无线回程线路,点对点微波,相阵列天线,C,X和Ku波段RADAR,测试设备和卫星调制解调器.本文介绍了LTC5552主要特性,功能框图,标准测试电路图和应用电路以及演示电路DC2668A主要特性,上/下变换混频双音测量建立图,电路图和材料清单.
The LTC®5552 is a high performance, microwave doublebalanced passive mixer that can be used for frequencyupconversion or downconversion. The device is similarto the LTC5553, but with a broadband, differential DC to6GHz IF port. The LTC5552 is recommended for applicationswhere the IF frequency range extends below 500MHz.For applications where the IF frequency is always above500MHz, the LTC5553 is recommended, since it includesan integrated IF balun.
The mixer and integrated RF balun are optimized to coverthe 3GHz to 20GHz RF frequency range. The integrated LOamplifier is optimized for the 1GHz to 20GHz frequencyrange, requiring only 0dBm drive.The part delivers high IIP3 and P1dB, low LO leakage andhigh integration in a small package.
LTC5552主要特性:
Integrated LO Buffer: 0dBm LO Drive
50Ω Wideband Matched RF and LO Ports
Wide IF Bandwidth: DC to 6GHz..
查看全文
