[原创] Maxim MAX14827A低功耗超小型IO-Link收发器解决方案
关键词:工业应用 IO-Link收发器 MAX14827A
时间:2017-08-09 09:52:56       作者:Maxim       来源:中电网
Maxim公司的MAX14827A是低功耗超小型双驱动IO-Link收发器,工作电压从通常的24V到高达60V,具有灵活控制接口,引脚控制逻辑输入允许开关传感器不需要微控制器(MCU),集成了3.3V和5V线性稳压器,主要用在工业传感器,IO-Link传感器和激励器以及安全应用.本文介绍了MAX14827A主要优势和特性,框图,典型应用电路图以及MAX14827评估板EVK主要特性,电路图,材料清单和PCB设计图.
The MAX14827A integrates the high-voltage functionscommonly found in industrial sensors, including driversand regulators. The MAX14827A features two ultra lowpowerdrivers with active reverse-polarity protection.
Operation is specified for normal 24V supply voltagesup to 60V. Transient protection is simplified due to highvoltage tolerance allowing the use of micro TVS.
The device features a flexible control interface. Pincontrollogic inputs allow for operation with switchingsensors that do not use a microcontroller. For sensors thatuse a microcontroller, an SPI interface is available withextensive diagnostics. For IO-Link operation, a three-wireUART interface is provided, allowing interfacing to themicrocontroller UART. Finally, a multiplexed UART/SPIoption allows using one serial microcontroller interface forshared SPI and UART interfaces.
The device includes on-board 3.3V and 5V linearregulators for low-noise analog/logic supply rails.
查看全文
