[原创] NXP LPC546XX系列32位ARM MCU嵌入应用开发方案
关键词:MCU 嵌入应用 LPC546XX
时间:2017-07-17 10:56:40       作者:NXP       来源:中电网
NXP公司的LPC546XX系列是基于32位ARM Cortex-M4核的MCU,具有系统增强功能如低功耗,增强的调试特性,集成了高等级的支持区块.器件采用3级流水线,具有单独本地指令和数据总线以及用于外设的第三总线的哈佛架构,集成了多达512KB 闪存,200KB SRAM,高速USB device/host + PHY,全速USBdevice/host,以太网AVB, LCD; EMC; SPIFI; CAN FD,SDIO, SHA,12-bit 5 MSPS ADC; DMIC子系统,工作频率高达220MHz,主要用在嵌入式应用领域.本文介绍了LPC546XX系列主要特性和优势,框图,以及LPCXpresso546xx系列评估板主要特性和主要特性布局图,框图,电路图和材料清单.
The LPC546xx is a family of ARM Cortex-M4 based microcontrollers for embedded applications featuring a rich peripheral set with very low power consumption and enhanced debug features.
The ARM Cortex-M4 is a 32-bit core that offers system enhancements such as low power consumption, enhanced debug features, and a high level of support block integration. The ARM Cortex-M4 CPU incorporates a 3-stage pipeline, uses a Harvard architecture with separate local instruction and data buses as well as a third bus for peripherals, and includes an internal prefetch unit that supports speculative branching. The ARM Cortex-M4 supports single-cycle digital signal processing and SIMD instructions. A hardware floating-point processor is integrated into the core.
查看全文
