[原创] Linear LTC6432-15 100kHz-1.4GHz差分ADC驱动方案
关键词:仪器仪表 放大器 ADC IF放大器 LTC6432-15
时间:2017-06-28 10:41:56       作者:Linear        来源:中电网
Linear公司的LTC6432-15是100kHz-1.4GHz的差分ADC驱动器/IF放大器,1MHz时100欧姆差分负载OIP3为54.4dBm,而150MHz时100欧姆差分负载OIP3为48.0dBm,输出功率高达15dBm,240MHz时的NF为3.0dB,单电源5V工作,主要用差分1GHz带宽ADC驱动器,宽带测试仪表放大器,差分IF放大器和50Ω/75Ω平衡IF放大器.本文介绍了LTC6432 -15主要特性,框图,应用电路,以及演示板DC2496A-A/B电路图,材料清单和PCB设计文件.
The LTCR6432-15 is an ultra-high dynamic range differentialgain block amplifier designed to drive high resolution,high speed ADCs. It offers a full GHz of data bandwidth forcomplex spectrally efficient modulations schemes or whereresistance to blockers is critical. This unique device cansimultaneously achieve low noise, incomparable linearity and flat gain over the 100kHz to 1GHz band.
Unlike wideband GaAs PHEMTs, MESFETs and GaN FETs,this SiGe based amplifier exhibits low 1/f noise and canbe used down to 100kHz.
The LTC6432-15 is designed for ease of use requiring aminimum of support components. Impedance matching,temperature compensation and bias control are handledinternally to ensure consistent performance over environmentalchanges.
All A-Grade LTC6432-15 devices are tested and guaranteedfor OIP3 at 150MHz. The LTC6432-15 is housed ina 4mm × 4mm, 24L, QFN package with an exposed padfor thermal management and low inductance.For a single-ended 50Ω IF Gain Block with similar performance,see the related LTC6433-15.
LTC6432 -15主要特性:
nn100kHz to 1400MHz Bandwidth
nn54.4dBm OIP3 at 1MHz into a 100Ω Diff Load
nn48.0dBm OIP3 at 150MHz into a 100Ω Diff Load
nnUp to 15dBm Output Power
nnNF = 3.0dB at 240MHz
nnLow 1/f Noise Corner
nnUser Defined Low Frequency
nn15.2dB Fixed Power Gain
nnA-Grade 100% OIP3 Tested at 150MHz
nn0.8 nV/√Hz Total Input Noise
nn>2.75VP-P Linear Output Swing
nnP1dB = 22.5dBm
nnInsensitive to VCC Variation
nnInput/Output Internally Matched to 100Ω Differential
nnSingle 5V Supply
nnDC Power = 850mW
nnUnconditionally Stable
LTC6432 -15应用:
nnDifferential 1GHz Bandwidth ADC Driver
nnWideband Test Instrument Amplifier
nnDifferential IF Amplifier
nn50Ω/75Ω Balanced IF Amplifier
图1.LTC6432 -15框图
图2.LTC6432 -15应用电路图
图3.LTC6432 -15差分放大器测试电路A(平衡放大器)
图4.DC2496A平衡放大器电路:50欧姆输入和50欧姆输出
图5.DC2496A没安装平衡/不平衡的外形图:左:正面;右:背面
图6.DC2496A安装平衡/不平衡的外形图:左:正面;右:背面
演示板DC2496A
Demonstration circuit 2496A features the LTC6432-15differential ADC Driver/IF Amplifier. The LTC®6432-15 hasa fixed power gain of 15.9dB and works from 100kHzto 1400MHz. It is part of the high linearity LTC643X-YYamplifier series.
As a differential amplifier, the LTC6432-15 offers flat gainand impressive linearity from 100kHz to 1GHz using asingle output bias network. Since high fidelity differentialtest equipment is lacking, the DC2496A offers singleended inputs and outputs so that the LTC6432-15 performancemay be evaluated with standard test equipment.
The native LTC6432-15 has 100Ω differential source andload impedances, so the demo circuit uses 2:1 transformersto convert the differential input/output impedances to50Ω single-ended impedance.
图7.演示板DC2496A-A简化电路图
图8.演示板DC2496A-B简化电路图
图9.演示板DC2496A测量建立图
图10.演示板DC2496A PCB安装图(正面)
图11.演示板DC2496A PCB安装图(背面)
演示板DC2496A材料清单见:
DC2496A-2.XLS
演示板DC2496A PCB设计文件见:
DC2496A.zip
详情请见:
http://cds.linear.com/docs/en/datasheet/643215f.pdf
http://cds.linear.com/docs/en/demo-board-manual/DC2496AAF.PDF
以及http://cds.linear.com/docs/en/demo-board-schematic/DC2496A-2-SCH.PDF
643215f.pdf
DC2496AAF.PDF
DC2496A-2-SCH.PDF
