[原创] TI AMC1304多相电能测量系统参考设计TIDA-01088
关键词:电源管理 电能测量系统 ΔΣ调制器 AMC1304
时间:2017-05-10 10:11:58       作者:TI        来源:中电网
TI公司的AMC1304是集成了LDO的高精度输入输出隔离的ΔΣ调制器,隔离层高达7000VPEAK,符合DIN V VDE V 0884-10,UL1577和CSA标准,具有极好的DC性能,支持高精度系统检测:失调误差±50 μV或±100 μV,失调漂移小于1.3 μV/¡ãC,增益误差±0.2%或 ±0.3%,增益漂移小于±40 ppm/°C,主要用于基于并联电阻的电流检测如工业马达驱动器,光伏逆变器和UPS以及隔离电压测量.本文介绍了AMC1304主要特性,功能框图,频率逆变器应用电路图,以及多相电能测量系统参考设计TIDA-01088主要特性和系统指标,框图,电路图,主要元件分布图和PCB设计图.
The AMC1304 is a precision, delta-sigma (ΔΣ)modulator with the output separated from the inputcircuitry by a capacitive double isolation barrier that ishighly resistant to magnetic interference. This barrieris certified to provide reinforced isolation of up to7000 VPEAK according to the DIN V VDE V 0884-10,UL1577 and CSA standards. Used in conjunction withisolated power supplies, the device prevents noisecurrents on a high common-mode voltage line fromentering the local system ground and interfering withor damaging low voltage circuitry.
The input of the AMC1304 is optimized for directconnection to shunt resistors or other low voltagelevelsignal sources. The unique low input voltagerange of the ±50-mV device allows significantreduction of the power dissipation through the shuntwhile supporting excellent ac and dc performance. Byusing an appropriate digital filter (that is, as integratedon the TMS320F2807x or TMS320F2837x families) todecimate the bit stream, the device can achieve 16bits of resolution with a dynamic range of 81 dB (13.2ENOB) at a data rate of 78 kSPS.
On the high-side, the modulator is supplied by anintegrated low-dropout (LDO) regulator that allows anunregulated input voltage between 4 V and 18 V(LDOIN). The isolated digital interface operates froma 3.3-V or 5-V power supply (DVDD).
The AMC1304 is available in a wide-body SOIC-16(DW) package and is specified from –40°C to+125°C.
AMC1304主要特性:
1• Pin-Compatible Family Optimized for Shunt-Resistor-Based Current Measurements:
– ±50-mV or ±250-mV Input Voltage Ranges
– CMOS or LVDS Digital Interface Options
• Excellent DC Performance Supporting High-Precision Sensing on System Level:
– Offset Error: ±50 μV or ±100 μV (max)
– Offset Drift: 1.3 μV/¡ãC (max)
– Gain Error: ±0.2% or ±0.3% (max)
– Gain Drift: ±40 ppm/°C (max)
• Safety-Related Certifications:
– 7000-VPK Reinforced Isolation per DIN V VDEV 0884-10 (VDE V 0884-10): 2006-12
– 5000-VRMS Isolation for 1 Minute per UL1577
– CAN/CSA No. 5A-Component AcceptanceService Notice, IEC 60950-1, and IEC 60065
End Equipment Standards
• Transient Immunity: 15 kV/μs (min)
• High Electromagnetic Field Immunity
• External 5-MHz to 20-MHz Clock Input forEasier System-Level Synchronization
• On-Chip 18-V LDO Regulator
• Fully Specified Over the Extended IndustrialTemperature Range
AMC1304应用:
• Shunt-Resistor-Based Current Sensing In:
– Industrial Motor Drives
– Photovoltaic Inverters
– Uninterruptible Power Supplies
• Isolated Voltage Measurements
图1.AMC1304功能框图
图2.AMC1304简化应用电路图
图3.AMC1304频率逆变器应用电路图
参考设计TIDA-01088
This reference design measures power qualityparameters in a polyphase energy measurementsystem and calculates total harmonic distortion (THD),fundamental readings, and standard metrologyparameters such as active and reactive energy andpower. Phase-to-phase angles are also calculated tohelp prevent incorrect installation of the system. Thisdesign uses isolated shunt current sensors to maintainaccuracy in harmonic analysis and also immunity frommagnetic tamper attacks.
The TIDA-01088 reference design implements power quality parameter measurement in a polyphase energy measurement system. Total harmonic distortion (THD), fundamental readings, and standard metrology parameters such as active and reactive energy and power are calculated. Phase to phase angles are also calculated to help prevent incorrect installation of the system. This design uses isolated shunt current sensors to maintain accuracy in harmonic analysis and also immunity from magnetic tamper attacks.
参考设计TIDA-01088主要特性:
Class 0.5% Three-phase metrology with galvanically isolated shunt current sensors
Isolation performance of up to 1-kV AC (working voltage) and 7 kV (Peak)
Total Harmonic Distortion (THD) calculated for Voltage and Current
Voltage Sag and Swell events logged with programmable threshold levels
Phase to Phase angle measurement for determining phase sequence to help prevent incorrect installation of system
Complete Energy Library with Fundamental Voltage and Current, Fundamental Active and Reactive power, Active and Reactive Energy, Root Mean Square(RMS) Current and Voltage, Power Factor, and Line Frequency
参考设计TIDA-01088主要应用:
• Power Quality Meters
• Power Quality Analyzers
• Power Distribution Unit
• Street Lighting
• Electricity Meters
参考设计TIDA-01088主要系统指标:
图4.参考设计TIDA-01088系统框图
图5.参考设计TIDA-01088外形图
图6.参考设计TIDA-01088主要元件分布图
图7.参考设计TIDA-01088电路图(1)
图8.参考设计TIDA-01088电路图(2)
图9.参考设计TIDA-01088电路图(3)
参考设计TIDA-01088材料清单:
图10.参考设计TIDA-01088 PCB设计图(正面)
图11.参考设计TIDA-01088 PCB设计图(背面)
详情请见:
http://www.ti.com/lit/ds/symlink/amc1304m05.pdf
http://www.ti.com/lit/ug/tidubo7a/tidubo7a.pdf
以及https://www.ti.com/seclit/df/tidrlm7/tidrlm7.pdf
https://www.ti.com/seclit/df/tidrlm8/tidrlm8.pdf
https://www.ti.com/seclit/df/tidrlm9/tidrlm9.pdf
amc1304m05.pdf
tidubo7a.pdf
