关键词:电源管理 AC/DC转换器 LinkSwitch-XT2
时间:2017-04-14 15:54:59 作者:Power 来源:中电网
摘要:Power Integrations公司的LinkSwitch-XT2系列是高效离线开关电源IC,集成了725V功率MOSFET,振荡器,简便ON/OFF控制方案,高压开关电流源,频率抖动,逐个周期限流和热关断电路.具有容易设计和优于线性/RCC的特性,主要用在电器,工业系统和仪表的电源.本文介绍了LNK3604产品亮点和功能框图,典型应用电路以及2.5W通用输入非隔离反激转换器参考设计DER-578主要特性,电路图,材料清单和PCB设计图.
LinkSwitch™-XT2 incorporates a 725 V power MOSFET, oscillator, simple ON/OFF control scheme, a high-voltage switched current source, frequency jittering, cycle-by-cycle current limit and thermal shutdown circuitry onto a monolithic IC. The start-up and operating power are derived directly from the DRAIN pin, eliminating the need for a bias winding and associated circuitry.
LNK3604产品亮点:
Easy to Design
Lowest component count switcher solution
Selectable device current limit
Fully integrated auto-restart for short-circuit and open-loop protection
Optional self-biased supply
Frequency jittering greatly reduces EMI
Meets HV creepage requirements between DRAIN and all other pins both on the PCB and at the package
Pin-out simplifies PCB heat sinking
Features Superior to Linear/RCC
Output overvoltage protection (OVP)
Input overvoltage line protection (OVL)
Hysteretic over-temperature protection (OTP)
Extended creepage between DRAIN pin and all other pins improves field reliability
725 V MOSFET rating for excellent surge withstand
Extremely low component count enhances reliability Allows single-sided PCB and full SMD manufacturability
EcoSmart™ – Extremely Energy-Efficient
Easily meets all global energy efficiency regulations
No-load consumption <100 mW without bias winding at 265 VAC input (<10 mW with bias winding)
ON/OFF control provides constant efficiency to very light loads
LNK3604应用:
Supplies for appliances, industrial systems, and metering
图1.LNK3604功能框图
图2.LNK3604通用输入设计电路
2.5W参考设计DER-578主要特性:
· Lowest component count for a non-isolated flyback solution
· Output voltage regulation, ±5%
· Programmable current limit for clampless design
· Reduced dissipation during output short circuit fault
· <10 mW no-load input power at 230 VAC
· >75% Efficiency at full load condition
· >6 dB conducted EMI margin
This engineering report describes a non-isolated flyback converter designed to provide a
nominal output voltage of 5 V at 500 mA load from a wide input voltage range of 85 VAC
to 265 VAC. This adapter utilizes the LNK3604D from the LinkSwitchTM-XT2 family of
devices.
图3.2.5W参考设计DER-578外形图(顶视图)
图4.2.5W参考设计DER-578外形图(底视图)
2.5W参考设计DER-578主要指标:
图5.2.5W参考设计DER-578电路图
2.5W参考设计DER-578材料清单:
图6.2.5W参考设计DER-578 PCB设计图(顶层)
图7.2.5W参考设计DER-578 PCB设计图(底层)
图8.2.5W参考设计DER-578变压器电路图
详情请见:
ac-dc.power.com/design-support/product-documents/data-sheets/linkswitch-xt2-data-sheet/">https://ac-dc.power.com/design-support/product-documents/data-sheets/linkswitch-xt2-data-sheet/
和
