[原创] Infineon XMC1302马达控制解决方案
关键词:ARM Cortex-M0 MCU 马达控制 数字电源
时间:2017-02-14 10:55:17       作者:Infineon       来源:中电网
Infineon公司的XMC1302是基于32位ARM Cortex-M0处理器核的XMC™1000系列中一员,具有超低功耗,8KB ROM,16KB高速SRAM和高达200KB 闪存程序和数据存储器,以及多种通信接口,模拟前端接口和工业控制接口,主要用在马达控制,数字电源转换和LED照明等.本文介绍了XMC1302主要特性,系统框图,以及评估板Eval_M1-1302主要特性和框图,电路图,材料清单和PCB设计图.
The XMC1300 devices are members of the XMC™1000 Family of microcontrollers based
on the ARM Cortex-M0 processor core. The XMC1300 series addresses the real-time
control needs of motor control, digital power conversion. It also features peripherals for
LED Lighting applications.
XMC1302主要特性:
CPU Subsystem
• CPU Core
– High-performance 32-bit ARM Cortex-M0 CPU
– Most 16-bit Thumb and subset of 32-bit Thumb2 instruction set
– Single cycle 32-bit hardware multiplier
– System timer (SysTick) for Operating System support
– Ultra low power consumption
• Nested Vectored Interrupt Controller (NVIC)
• Event Request Unit (ERU) for processing of external and internal service requests
• MATH Co-processor (MATH)
– CORDIC unit for trigonometric calculation
– division unit
On-Chip Memories
• 8 kbytes on-chip ROM
• 16 kbytes on-chip high-speed SRAM..
查看全文
