[原创] STSTEVAL-STLKT01V1 SensorTile开发方案
关键词:传感器模块 MEMS 可穿戴 物联网 IoT
时间:2017-02-01 09:16:42       来源:中电网
ST公司的STEVAL-STLKT01V1 SensorTile开发套件支持和扩展SensorTile传感器模块(13.5mm x 13.5mm),它包括MEMS加速度计,陀螺仪,磁力计,压力传感器和MEMS麦克风.开发板采用低功耗80 MHz STM32L476JGY微控制器来检测和低功耗蓝牙连接到集线器,以开发可穿戴设备,游戏附件,智能手机和物联网(IoT)设备.本文介绍了STEVAL-STLKT01V1主要特性和功能框图,以及套件中的STLCS01V1 SensorTile板,STLCR01V1 SensorTile板和STLCX01V1 SensorTile板主要特性,电路图和材料清单.
 The STEVAL-STLKT01V1 is a comprehensive development kit designed to support and expand the capabilities of the SensorTile and comes with a set of cradle boards enabling hardware scalability. The development kit simplifies prototyping, evaluation and development of innovative solutions. It is complemented with software, firmware libraries and tools, including a dedicated App.
The SensorTile is a tiny, square-shaped IoT module that packs powerful processing capabilities leveraging an 80 MHz STM32L476JGY microcontroller and Bluetooth low energy connectivity based on BlueNRG network processor as well as a wide spectrum of motion and environmental MEMS sensors, including a digital microphone.
SensorTile can fit snugly in your IoT hub or sensor network node and become the core of your solution.
STEVAL-STLKT01V1主要特性:
 FCC (ID: S9NSTILE01) and IC (IC: 8976C-STILE01) certified
 Included in the development kit package:
 SensorTile module
 SensorTile expansion Cradle board equipped with audio DAC, USB port, STM32 Nucleo, Arduino UNO R3 and SWD connector
 SensorTile Cradle with battery charger, humidity and temperature sensor, SD memory card slot, USB port and breakaway SWD connector
 100 mAh Li-Ion battery
 Plastic box for housing the SensorTile cradle and the battery
 SWD programming cable
 Software libraries and tools
 STSW-STLKT01: SensorTile firmware package that supports sensors raw data streaming via USB, data logging on SDCard, audio acquisition and audio streaming. It includes low level drivers for all the on-board devices
 BLUEMICROSYSTEM1 and BLUEMICROSYSTEM2: STM32Cube expansion software package, supporting different algorithms tailored to the on-board sensors
 FP-SNS-ALLMEMS1 and FP-SNS-MOTENV1: STM32 ODE functional packs
 ST BlueMS: iOS and Android demo Apps
 BlueST-SDK: iOS and Android Software Development Kit
 Compatible with STM32 ecosystem through STM32Cube support
图1.STEVAL-STLKT01V1开发套件外形图
STEVAL-STLKT01V1开发套件核心系统主要特性:
LSM6DSM 3D accelerometer + 3D gyroscope
LSM303AGR 3D Magnetometer + 3D accelerometer
LPS22HB pressure sensor/barometer
MP34DT04 digital MEMS microphone
STM32L476 microcontroller
BlueNRG-MS network processor with integrated 2.4GHz radio
STEVAL-STLKT01V1开发套件包括:
1.STLCS01V1 SensorTile板
图2.STLCS01V1 SensorTile板外形图
STLCS01V1 SensorTile板主要特性:
 Very compact module for motion, audio and environmental sensing and Bluetooth low energy connectivity with a complete set of firmware examples
 Supported by the BLUEMICROSYSTEM1 and BLUEMICROSYSTEM2 software expansion package for STM32Cube and the STM32 ODE functional pack FP-SNS-ALLMEMS1
 Mobile connectivity via the ST BlueMS app, available for iOS and Android
 Main components:
 STM32L476 – 32-bit ultra-low-power MCU with CortexM4F
 LSM6DSM – iNEMO inertial module: 3D accelerometer and 3D gyroscope
 LSM303AGR – Ultra-compact high-performance eCompass module: ultra-low power 3D accelerometer and 3D magnetometer
 LPS22HB – MEMS nano pressure sensor: 260-1260 hPa absolute digital output barometer
 MP34DT04 – 64dB SNR Digital MEMS Microphone
 BlueNRG-MS – Bluetooth low energy network processor
 BALF-NRG-01D3 – 50 Ω balun with integrated harmonic filter
 LD39115J18R – 150 mA low quiescent current low noise LDO 1.8 V
 2 V-5.5 V power supply range
 External interfaces: UART, SPI, SAI (Serial Audio Interface), I²C, DFSDM, USB OTG, ADC, GPIOs
 Pluggable or solderable interface
 SWD interface for debugging and programming capability
2.STLCR01V1 SensorTile板
图3.STLCR01V1 SensorTile板外形图
STLCR01V1 SensorTile板主要特性:
 Sensortile Cradle board with SensorTile footprint (solderable)
 STBC08PMR – 800 mA standalone linear Li-Ion battery charger
 HTS221 – capacitive digital sensor for relative humidity and temperature
 LDK120M-R – 200 mA low quiescent current very low noise LDO
 STC3115 – Fuel gauge IC
 USBLC6-2P6 – very low capacitance ESD protection
 USB type A to Mini-B USB connector for power supply and communication
 microSD card socket
 SWD connector for programming and debugging
3.STLCX01V1 SensorTile板
图4.STLCX01V1 SensorTile板外形图
STLCX01V1 SensorTile板主要特性:
 Sensortile Cradle expansion board with SensorTile plug connector
 Compatible with STM32 Nucleo boards through Arduino UNO R3 connector
 ST2378ETTR – 8-bit dual supply 1.71 V to 5.5 V level translator
 16-Bit, low-power stereo audio DAC
 Micro-USB connector for power supply and communication
 Reset button
图5.STEVAL-STLKT01V1开发套件功能框图
图6.STEVAL-STLKT01V1开发套件电路图(1)
图7.STEVAL-STLKT01V1开发套件电路图(2)
图8.STEVAL-STLKT01V1开发套件电路图(3)
图9.STEVAL-STLKT01V1开发套件电路图(4)
图10.STEVAL-STLKT01V1开发套件电路图(5)
图11.STEVAL-STLKT01V1开发套件电路图(6)
图12.STEVAL-STLKT01V1开发套件电路图(7)
图13.STEVAL-STLKT01V1开发套件电路图(8)
图13.STEVAL-STLKT01V1开发套件电路图(9)
STEVAL-STLKT01V1开发套件材料清单:
详情请见:
http://www.st.com/content/ccc/resource/technical/document/data_brief/group0/01/fc/21/37/29/fe/
44/7b/DM00298488/files/DM00298488.pdf/jcr:content/translations/en.DM00298488.pdf
http://www.st.com/content/ccc/resource/technical/document/user_manual/group0/bc/b1/ad/c8/36/de/
40/92/DM00320099/files/DM00320099.pdf/jcr:content/translations/en.DM00320099.pdf
以及
http://www.st.com/content/ccc/resource/technical/layouts_and_diagrams/schematic_pack/group0/dd/ce/
e9/b5/8c/d1/4c/07/STEVAL-STLKT01V1%20schematic/files/steval-stlkt01v1_schematic.pdf/jcr:content/translations/en.steval-stlkt01v1_schematic.pdf
http://www.st.com/content/ccc/resource/technical/document/bill_of_materials/group0/07/2b/8e/6f/b6/
af/41/1d/STEVAL-STLKT01V1%20BOM/files/steval-stlkt01V1_bom.pdf/jcr:content/translations/en.steval-stlkt01V1_bom.pdf
en.DM00298488.pdf
en.DM00320099.pdf
