[原创] IDT P9242-R 15W无线电源发送器解决方案
关键词:ARM®Cortex-M0 MCU 电源管理 无线电源 P9242-15W
时间:2017-01-09 09:41:03       作者:IDT       来源:中电网
IDT公司的P9242-R是高度集成磁感应的15W无线电源发送器,包括提供高度可编程和待机功耗很低的32位ARM®Cortex®-M0处理器,输入电压从4.25V到21V.器件和WPC-1.2.2兼容,MP-A2线配置,支架I2C接口.主要用在充电板,充电架,电源配件和平板电脑.本文介绍了P9242-R主要特性,功能框图和应用电路,以及5W无线发送器(TX)评估板P9242-R-EVK主要特性,电路图,材料清单和PCB设计图.
The P9242-R is a highly integrated, magnetic induction, wirelesspower transmitter supporting up to 15W. The system-on-chipoperates with an input voltage range of 4.25V to 21V.The transmitter includes an industry-leading 32-bit ARM®Cortex®-M0 processor offering a high level of programmabilitywhile consuming extremely low standby power. The P9242-Rfeatures two LED outputs with pre-defined user-programmableblinking patterns, buzzer, and programmable over-currentprotection supporting a wide range of applications. The I2C serialcommunication allows the user to read information such asvoltage, current, frequency, and fault conditions. The P9242-Rincludes an under-voltage lockout and thermal management circuitto safe guard the device under fault conditions. Together withthe P9221-R receiver (RX), the P9242-R is a complete wirelesspower system solution.
查看全文
