[原创] Intersil ISL9237降压升压窄输出电压电池充电解决方案
关键词:电源管理 电池充电器 窄输出电压DC(NVDC)
时间:2016-10-24 09:54:51       作者:Intersil        来源:中电网
Intersil公司的ISL9237是集成了SMBus接口和USB OTG降压升压窄输出电压(NVDC)电池充电器,输入电压3.2V-23.4V,系统输出电压2.4V-13.824V,开关频率高达1MHz,主要用在带可充电电池的移动设备和带可充电电池的工业设备.本文介绍了ISL9237主要特性,应用电路和参考设计电路,以及评估板ISL9237EVAL2Z主要特性,框图,电路图,材料清单和PCB设计图.
The ISL9237 is a buck-boost Narrow Output Voltage DC (NVDC)charger utilizing Intersil’s advanced R3™ Technology to providehigh light-load efficiency, fast transient response and seamlessDCM/CCM transitions for a variety of mobile and industrialapplications.
In Charge mode, the ISL9237 takes input power from a widerange of DC power sources (conventional AC/DC chargeradapters, USB PD ports, travel adapters, etc.) and safely chargesbattery packs with up to 3 cells in a series configuration.
ISL9237 supports On-the-Go (OTG) function for 2- and 3-cellbattery applications. When OTG function is enabled, the ISL9237operates in the reverse Buck mode to provide 5V at the USB port.
查看全文
