[原创] Atmel SAM L21 32位MCU超低功耗可穿戴解决方案
关键词:ARM® Cortex-M0+ MCU 可穿戴 物联网(IoT) SAM L2
时间:2016-08-18 10:57:24       来源:中电网
Atmel公司的SMART SAM L21是基于32位ARM® Cortex®-M0+处理器的超低功耗MCU,最大工作频率48MHz(2.46CoreMark®/MHz),集成了高达256KB闪存和40KB SRAM,具有极专业的电源管理技术,高度可配置的外设如支持容性和接近式传感器的触摸控制器,非常适合用在可穿戴和物联网(IoT)市场.本文介绍了SAM L21主要特性,功能框图以及可穿戴演示板ATULPC-DEMO主要特性,框图和电路图.
Atmel® | SMART SAM L21 is a series of Ultra low-power microcontrollers using the 32-bit ARM® Cortex®-M0+ processor, and ranging from 32- to 64-pins with up to 256KB Flash and 40KB of SRAM. The SAML21 devices operate at a maximum frequency of 48MHz and reach 2.46 CoreMark®/MHz. They aredesigned for simple and intuitive migration with identical peripheral modules, hex compatible code,identical linear address map and pin compatible migration paths between all devices in the productseries. All devices include intelligent and flexible peripherals, Atmel Event System for inter-peripheral signaling, and support for capacitive touch button, slider and wheel user interfaces.
查看全文
