[原创] TI TIDA-00366 10kW三相逆变器参考设计
关键词:电源管理 IGBT驱动器 TIDA-00366
时间:2016-08-04 13:23:28       作者:TI       来源:中电网
TI公司的TIDA-00366是三相逆变器参考设计,采用隔离的双路IGBT栅极驱动器UCC21520,隔离的放大器AMC1301以及MCUTMS320F28027,200-690V AC驱动,额定功率高达10kW.具有较低的成本,和具有过载,短路,接地故障,欠压/过DC总线电压以及IGBT超温等保护功能.本文介绍隔离的放大器AMC1301主要特性,功能框图和应用电路,以及10kW三相逆变器参考设计TIDA-00366主要特性,框图,电路图,材料清单.
Reference Design for Reinforced Isolation 3-Phase Inverter with Current, Voltage and Temp Protection (PREVIEW) TIDA-00366
The AMC1301 device is a precision, isolated amplifier with an output separated from the input circuitry by an isolation barrier that is highly resistant to magnetic interference. This barrier is certified to provide reinforced galvanic isolation of up to 7 kVPEAK according to VDE V 0884-10 and UL1577. Used in conjunction with isolated power supplies, this device prevents noise currents on a high common-mode voltage line from entering the local ground and interfering with or damaging sensitive circuitry.
查看全文
