[原创] ST STM32L151VE可穿戴传感器参考设计STEVAL-WESU1
关键词:ARM Cortex-M3 MCU 可穿戴设备 传感器 应用控制 医疗和手持设备
时间:2016-06-13 09:42:24       作者:ST       来源:中电网
ST公司的STM32L151xE和STM32L152xE是超低功耗32位基于ARM® Cortex®-M3 RISC内核的MCU,集成了512KB闪存,80KB SRAM,16KB EEPROM,LCD,USB,ADC和DAC等外设,工作频率从32 kHz到高达32 MHz, 1.25 DMIPS/MHz (Dhrystone 2.1),工作电压1.65 V到3.6 V,主要用在医疗和手持设备,PC外设,游戏,GPS和运动设备,应用控制和用户接口,告警系统,有线和无线传感器,视频连接和公用表.本文介绍了STM32L151VEY6主要特性,框图和时钟树,以及可穿戴传感器STEVAL-WESU1系统参考设计,框图和固件架构图,电路图和材料清单.
Ultra-low-power 32-bit MCU ARM®-based Cortex®-M3 with 512KB Flash, 80KB SRAM, 16KB EEPROM, LCD, USB, ADC, DAC
The ultra-low-power STM32L151xE and STM32L152xE devices incorporate the connectivity power of the universal serial bus (USB) with the high-performance ARM® Cortex®-M3 32-bit RISC core operating at a frequency of 32 MHz (33.3 DMIPS), a memory protection unit (MPU), high-speed embedded memories (Flash memory up to 512 Kbytes and RAM up to 80 Kbytes), and an extensive range of enhanced I/Os and peripherals connected to two APB buses.
The STM32L151xE and STM32L152xE devices offer two operational amplifiers, one 12-bit ADC, two DACs, two ultra-low-power comparators, one general-purpose 32-bit timer, six general-purpose 16-bit timers and two basic timers, which can be used as time bases.
查看全文
